Search/download MusicVideo On Yahoo US,FR,AU,CA,DE,SP,UK
title says it all
Postby dgemily on Fri Dec 09, 2005 8:52 pm
Application built by The Lynx from the French team :
installation
- download and install Net Transport ( afree version is available there : http://www.gratilog.net/internet1.htm#nettransport)
- download XYahoo!Music :
http://www.france.xlobby.com/plugins/XY ... !Music.zip
(copy and past the link)
- unzip files in a same repertory :
Configuration
Edit Config.ini :
[PARAMETRES]
DataBase = C:\Program Files\XlobbyFr\databases\rechercheclips.xml
[CLIPS]
NetTransport = C:\Program Files\Xi\NetTransport 2\NetTransport.exe
Enregistrersous = G:\CLIPS
[SON]
Debut = C:\Program Files\XlobbyFr\applications\CineHoraire\debut.wav
Fin = C:\Program Files\XlobbyFr\applications\CineHoraire\fin.wav
[XEVENT]
XalarmPath = c:\Program Files\XLobbyFr\plugins\XEvent\XAlarmeNow.txt
XEventCmd = xxx|CmdXevent2Vbs:refreshXEYahoo!Clips
PARAMETRES: indicate the xlobby database that you want create
CLIPS : path to NetTransport.exe and the repertory where you want save your music videos
SON : Debut = the audio file that you want execute at the stat of the search and Fin = for the end of the search
XEVENT : indicate the event that you want execute at the end of the search ( of course you need Xevent plugin
the application ( without xlobby)
you can also use the application without xlobby
you need this 3 files :
- Yahoo!Music 1.3.1.exe
- AutoItDLL.dll
- config.ini
then execute "Yahoo!Music 1.3.1.exe
You can do a search on different Yahoo web sites
US = USA
FR = France
AU = Australia
CA = Canada
DE = Germany
ES = Spain
UK = United Kingdom
The option "Arborescence Xlobby" can give you a good structure of repertories in the aim of having an easy scan with xlobby . if this case is uncheck, all your files will be on the same repertory.
Make a search with the name of an artist , then click on 1 answer in the result list
In xlobby
screenshots are from Xmedia2-games skin.
1 –when there is any result.
2 – make a search
3 – result list.
At the first use the application will create a databases "rechercheclips.xml so you need to restart xlobby but only the first time
4 – you can play the streaming file, or download files using net transport.
5 - you can also make a search using your music database
6 – you can use spiders to download covers: here are some :
- clips - album - yahoo.fr.zip
- clips - artist - yahoo.com.zip
- clips - artist - yahoo.fr.zip
- clips - title - fnac.com.zip
- clips - title - yahoo.com.zip
integrate the application in a skin
- using an "input button":
create un event "execute file" pointing to "Yahoo!Music.exe" and in arguments :
"%button>input%" "all"
"all" to make a search on every yahoo web sites, if you want for example make a search only on yahoo usa use : "usa"
- using your music database :
"%music>artist%" "all"
you can add a command "go to" in this event, in the aim of going on the result search
- to download a music-video
"%clips>parameter%"
where "clips" is the category to display the result (database rechercheclips.xml)
enjoy!
Member of XLobby FR Team
Releases from the French team
dgemily
Postby rika on Sun Dec 11, 2005 10:39 pm
Yes!!! another one from the french team!!
Rika
rika
Postby rika on Mon Dec 12, 2005 2:09 pm
I can´t get the steaming to work (play the mms), downloads works perfect. Any trick to this?. Thanks
Rika
rika
Postby C-moi on Mon Dec 12, 2005 4:39 pm
did you try to play the streaming with Media Player Classic ?
File / Open File /
field Open : copy the mms link :wink:
C-moi
Postby rika on Tue Dec 13, 2005 9:09 am
Hmm, thats what i did... tryed mce, wmp and direct in explorer. Mce gives me somthing about that it can´t render or over zised the buffer. wmp says that it cant get to the file or that the proxysettings are wrong.
Tryed alot of different mms
mms://dalwmod038.bcst.yahoo.com/bmfroot03/BMFShare03/__S__/launch.com/1/2272097.asf#StreamID=2272097&pl_auth=2f6401e8a6b5ec06ecfbdd1d2f00972e&ht=3630&xdata=nRzJb0G4ijlR1imAI0eTbg-219590-1888031798&pl_b=00CEBE2C2CD4251EAE7FC6865C439D1CCF&s=396500550/Prince%20-%20My%20Name%20Is%20Prince.wmv
Rika
rika
Postby dgemily on Wed Dec 14, 2005 11:52 pm
rika, the link has an expiration time, so now I can't see if your link is ok or not....
anyway try with MPC "media player classic" not wmp... that should work...
dgemily
Postby rika on Thu Dec 15, 2005 7:54 am
Ops... should be mpc, I looked at the mpc forum and there is some people that have the same problem with .wma, asx, wmv (cant render the file) i´ll have to expremet with the mpc settings and see if i coluld solve this.
Thanks anyway.
Rika
rika
Postby dgemily on Thu Dec 15, 2005 9:01 am
ok,
maybe, try to add filters in mpc option, I'm not at home right now but if I remember, I have some filters activated. I will try to tell you which filters I have when I will go back to home.
Later,
dgemily
Postby rika on Thu Dec 15, 2005 7:12 pm
Thanks!
rika
Postby dgemily on Thu Dec 15, 2005 7:54 pm
I did a try without any "Overrides Filters" and it still working for me. so it's not the problem... sorry can't help you ...
did you try with another version of mpc ? to imform my tests was on the version 6.4.8.4
later
dgemily
Postby sagitaz on Thu Dec 15, 2005 10:45 pm
i have the same problem on my xlobby box and i try to install filter or codec and we don't forget the solution.
i think i install more codec pack and filter and desinstal this... and not work long time.
1 month ago, i format my xlobby box :twisted: , instal XP sp2 and all hotfix, don't install WMP 10, just wmp9 and i install the satsuki decoder pack 2.5.6.
now all off streaming video play and i don have problem. :lol:
sagitaz
Postby dalanik on Thu Feb 02, 2006 10:08 am
I have problem on 1 pc with this. I run Yahoo Music 3.x.x and it searches, but when i double click on a song, nothing happens even though I have NetTransport installed and correctly setup in config file. Any ideas?
Postby dgemily on Thu Feb 02, 2006 5:59 pm
dalanik wrote:I have problem on 1 pc with this. I run Yahoo Music 3.x.x and it searches, but when i double click on a song, nothing happens even though I have NetTransport installed and correctly setup in config file. Any ideas?
you don't see any mms links ? did you try with more than 1 song ?
maybe you can try to watch a clip directly on yahoo web site ( http://music.yahoo.com/ ) maybe you have to get a cookie....
I know that there is something about a"mediah" but the programme should simulate a valid one....
dgemily
Postby dalanik on Fri Feb 03, 2006 10:24 am
Weird, I got it working on one PC, but not the other. I get the mms link, and when I double click, Yahoo Music closes and nothing happens.
But when I run search.bat it creates database, and I can copy and paste mms link ito net transport and it works....
I'll try logging onto yahoo music and see whether it helps.
Thanx,
Dalibor
Postby dalanik on Fri Feb 03, 2006 10:46 am
No, it didn't help... :-(
Return to Tips and Tricks
