Command line switch
Command line switch
Postby jnd53 on Sun Jul 18, 2010 11:17 pm
I currently have a 10inch touch screen with Xlobby and my TV is the main monitor. I am using the OEM version of TMT that came with my Xonar HDAV 1.3 audio card. It works perfectly to receive the HD audio from the bluray folders on my hard drive.
I can get Xlobby to open the TMT and open the m2ts file to start the movie however doing so I do not get the HD audio, if I open the folder using TMT drop down box to select folder I do get the HD audio. Does anybody here know the command line switch to open the folder instead of the file? I am currently using this command line switch
“%parameter%”
Thanks Jerry
jnd53
Return to General Discussion
