Music Top played, question
Postby lar282 on Thu Jan 08, 2009 12:04 pm
Does any here have a solution for this?
Press a button in Xl that plays the 50 most played mp3's
Everytime I play a mp3 in XL it should increment a played=played+1 (maybe using the playcount plugin in foobar)
thought I should ask before creating a plugin. Oh and I use Foobar, not winamp
Thanks in advance.
Re: Music Top played, question
Postby scottw on Thu Jan 08, 2009 12:52 pm
lar282 wrote:Hi
Thanks in advance.
There's xDatabase that does this although I have never gotten it to work correctly for me and I am not sure if it works for Foobar.
Scott
Postby S Pittaway on Fri Jan 09, 2009 2:15 pm
The plugin was xMusic, but it doesent support multi zones and i dont use foobar so not sure if it works or not...
It also doesn't seam to work correctly on V3.
Really xlobby should do this out of the box-
auto set played times\counters
user rating system (say 1 - 5 stars)
smart play lists - play favourites. un-played etc
Its a bit of a pain doing it via a plugin, someone with access to the core could get it working in a few hours.
Return to General Discussion
