Free Button Designer
Postby Bill Lott on Sat Dec 27, 2008 2:11 pm
If you do not use photoshop or a similar program and want to design your own buttons, this may be useful to you.
It's available free today at http://www.giveawayoftheday.com/button-3-shop/
I just loaded it and has some nice effect tools.
Bill Lott
________________
Now Playing: Image
Bill Lott
Re: Free Button Designer
Postby wesblack on Sat Dec 27, 2008 8:52 pm
Bill,
Thanks for sharing. I downloaded the software and it does have some nice features and it is easy to create buttons. We have discussed adding this type of power to create buttons directly in xLobby so eventualy one day this may happen. Below is a screenshot of buttons I created using Button Shop 3. If you want to create buttons for xLobby do the following.
1. Under Font select color
2. Next Select web.
3. Select Transparent
4. Under shadow set visibility to 0%
5. Type any text in the text box to provide the width of the button you want
6. Select a color and direction to build buttons to create a standard button and a enter button for xLobby and save them as two seperate files.
Screenshot:
Return to General Discussion
