(Animated Background) Matrix Effect AVI File for V3
Postby wesblack on Tue May 12, 2009 2:46 pm
I want to thank Brett Triola from AVI Audio Visual Installations for sharing these files.
Matrix Effect (Green), large file, please be patient for the preview
Matrix Effect (Blue), large file, please be patient for the preview
You can add (.avi. .mpg or .wmv) videos into the background folder of any xLobby skin for use as a animated background. Your system should have a video card installed that performs hardware rendering to minamize heavy cpu load. Make sure you have Windows Media Player 11 or above installed or the background will not render.
New Background Animation Events under Comannd Group (xLobby):
1. Background Play
2. Background Stop
3. Background Set, selects the different file locations for background animations, static .jpg images or even web based images, example: "c:\My Animations\waveanimation.wmv"
Websites to download free WMV files for xLobby animated backgrounds:
http://www.movietools.info/index.php?op ... 4d8a578910
http://www.dreamscene.org/gallery.php?p ... oadgallery
Additional website, requires conversion to WMV:
http://stockfootageforfree.com/
Website to download paid WMV files for xLobby animated backgrounds, requires conversion to WMV:
http://www.pond5.com/stock-video-footag ... gwodLyD7hg
Free online file conversion:
http://media-convert.com/
Re: (Animated Background) Matrix Effect AVI File for V3
Postby billberet on Tue May 12, 2009 7:14 pm
Hey Wes,
will there be any issues with animated backgrounds, i find the server comes to a crawl after a few days of having animated background, especially if it has to load a 9meg file every time you enter the page. The 'quickness' of XL gets compromised when the animated backs are used.
Granted, i tried it a few Rev's ago, has there been any code changes to handle the animated backgrounds, or is that the same?
I do love the animated BG, but i can't justify the performance loss when they are used.
Postby aviaudio on Wed May 13, 2009 11:47 pm
I have not noticed any issues with the backgrounds slowing my machine down. I have been running both of the matrix screens as well as others and every page still loads the same with or without animation. I have a ton others I will post up soon to share. Sorry about the Matrix files being so large, I have not found the limitations of Xlobby! I'm not to sure there are any :D
aviaudio
Postby billberet on Thu May 14, 2009 12:42 am
sounds good, i'll give it a try.
have you noticed any delay on loading up the page when you have the BG's on.
the pages work great after they are loaded, but there is a second delay to get the icons up.
do your pages start up in the same amount as when you use a standard background?
i was using the WMV files, that could have been an issue, i'll try your avi files.
Postby billberet on Thu May 14, 2009 11:23 pm
keep those avi files comming.
they work great, no lag at all compared to the wmv files, like night and day.
the pages loaded just as fast as a static background.
thanks again
Postby aviaudio on Fri May 15, 2009 2:25 am
Here is another one of my favorites.
aviaudio
Postby wesblack on Fri May 15, 2009 4:41 am
Thats cool.........!
Dont forget that you can convert WMV file types to AVI using the media-convert.com website.
Postby billberet on Fri May 15, 2009 2:39 pm
yea wes, sounds like a good idea.
i do like the 'news room' wmv files i have, looks real nice when i'm displaying information.
i'll give it a try.
Postby billberet on Fri Jun 19, 2009 2:53 pm
hey AVIAUDIO,
hope you don't mind, i am using your matrix theme for my xlobby, but i am doing my own HUD type display.
you know how the HP commercial's work. i am making the framework of putting myself in my menu.
i draw the screen, it pops up, then xlobby is displayed in the window.
i did a little test and i fell off my chair cause it was working out nicely.
here is a clip of the footage, i tried to embed it but didn't have any luck :) so you'll have to click below.
http://www.cyberdyne-sys.com/upload/laughtest.mov
Postby aviaudio on Sat Jul 11, 2009 2:03 am
Wow, that looks cool! Check this one out,
aviaudio
Postby billberet on Sat Jul 11, 2009 2:48 am
i like it, looks good
nice job.
Return to Graphics and Skinning
