DVD Copy
V3 plugins
DVD Copy
Postby Bill Lott on Sat Dec 04, 2010 10:43 pm
When i try to copy a DVD within xLobby I am getting a message that says "You may be out of hard drive space" although there is plenty of space remaining. If I run DVDfab directly I do not have any problems. I have deleted and re-entered the drive locations within the plugin, but I still get this message within xLobby. I suspect that there older settings are still stored within xLobby somewhere that is causing this. Any suggestions on where to look?
Bill Lott
________________
Now Playing: Image
Bill Lott
Re: DVD Copy
Postby samsonlov on Sun Dec 05, 2010 7:10 pm
First, did you get xLobby to run on your "C"?
Second, I always keep a "default" clean (only default plugins) instance of xLobby in "c:/program files/xlobby default".
This way, when something doesn't work as expected in my "custom" version, I can always quickly download the latest build and "keep and replace" the xLobby in "c:/program files/xlobby default" and make sure the problem is only in my "custom skin".
This has saved me a ton of time troubleshooting.
Re DVDFAB:
I would start be making sure you've got the latest version of DVDFAB (I'm using 8.0.22 with no issues).
