screensaver select command?
Postby S Pittaway on Mon Mar 19, 2012 12:00 pm
Not sure how long its been there in its current form but i just noticed that the screensaver now plays a slideshow for pictures/moves - much better by the way.
But the screensaver is pretty cpu intensive so i need to set it to blank when playing a video or watching tv.
You seen to be missing commands to let me select a screensave type or the delay before its shown?
There are commands to cycle thro the types etc but none to set it to an absloute value.
If i am not missing them could we have
screen saver set type>database
screen saver set time before shown>delay in mins
The code is already there so adding a event should only take a feww mins..
Cheers, Sean.
Re: screensaver select command?
Postby stevenhanna6 on Tue Mar 20, 2012 8:05 pm
Screensaver just recently got changed, twice actually, one was a memory bug with high res photos like 3000x3000px+, and the timing fade function was off a but. Never caught it before.
I added xlobby "screensaver type set", and "screensaver timer set" to the bleeding edge you can use those function.
Return to Support
