xseer plugin always unchecking itself
Postby billberet on Thu Feb 03, 2011 2:48 am
hey,
has anyone had any issues with the xseer plugin for XL. i have updated to Bleeding edge version.
this has been happening for a few months, but now it seems to happen every day.
i have to keep going into setup to check off the 'connect at startup' checkbox, then restart XL.
does anyone else have this issue, or found a way to keep the checkbox checked?
thanks
-bb
Re: xseer plugin always unchecking itself
Postby billberet on Wed Mar 16, 2011 2:17 am
found the issue, Bill L. and myself was talking and he told me to check the auto update feature.
and sure enough, the bleeding edge update was checked.
i unchecked it, and my plugin has been working ever since
good job bill!
Return to Support
