XL 3 on Server 2003 - Won't Start At All
Postby PhilB on Fri Dec 19, 2008 1:30 am
Just rebuilt my server after a bad drive crash. Went with 2-500gig drives and Windows 2003 Standard Server. Drives in mirror.
Installed .Net 3.5 and applied SP1 to that. O/S has SP2 on it.
XL just crashes before getting even part of the way starting up. Never gets to my skin files. This is the error in the event log:
Source .Net 2.0 Runtime Error:
EventType clr20r3, P1 xlobby2.exe, P2 3.0.8350.4, P3 4945f4b3, P4 dshowplayer, P5 0.0.0.0, P6 49008c01, P7 65, P8 2, P9 system.nullreferenceexception, P10 NIL.
Running the latest 3.0 version.
Any help would be appreciated.
PB
PhilB
Re: XL 3 on Server 2003 - Won't Start At All
Postby lar282 on Fri Dec 19, 2008 7:18 am
I think thats a directshow crash. Win server 2003 doesn't have video acc 100%, but I think u can get around it. think I saw something on the net about video acceleration on server. plus u need directx. V3 of Xlobby loads all that stuff at startup.
http://www.petri.co.il/enable_graphic_a ... s_2003.htm
Postby PhilB on Fri Dec 19, 2008 7:20 pm
Thanks Lar but that did not resolve the issue. I also read that having Visual Studio installed could help to resolve the issue but that also did not help.
the last thing XL says when loading is "Sound" and then crashes. Same error in the event log after all the changes.
All the reading I have done points to a missing DLL(s). I have no idea which one a this point but will keep looking.
PB
PhilB
Postby Bill Lott on Sat Dec 20, 2008 5:20 am
not sure this will make you feel any better - but, I'm running version3 on Server 2003 without any problems.....
seems like I had once had a similar problem and deleting the wav startup file fixed it.
Bill Lott
________________
Now Playing: Image
Bill Lott
Postby PhilB on Sat Dec 20, 2008 5:05 pm
Bill,
You win the award! This actually worked. After moving all the .wav files out of the XL defaul skin, it started up fine. Man, I wasted way too much time on this chasing this issue for it to be so simple a fix.
THANKS ALOT!
PB
PhilB
Postby lar282 on Sat Dec 20, 2008 9:38 pm
just curious. can that machine play audio? I mean from inside xlobby?
why does it bail on a wav? wierd!
Postby PhilB on Sun Dec 21, 2008 4:38 am
Well it used to when I used XP and XL 3.0. I have since been rebuilding with new drives and Server 03. No other hardware changed besides the drives.
Since I am reworking my skin, I will let you know about the audio.....
[EDIT]
Yes, the audio works fine....
PhilB
Return to Support
