IP Cam - set-up
Video streaming sites and links to streams
IP Cam - set-up
Postby vaporhat on Fri Nov 20, 2009 4:23 am
I have 4 IP cameras with separate IP addresses that I would like to stream into XL as opposed to looking at snapshot .jpg's.
I am looking for a little direction as to how to go about this? Any idea?
4 separate IE windows? or is there a better way?
-3RiC
Re: IP Cam - set-up
Postby wesblack on Tue Dec 01, 2009 4:06 pm
You can have 4 separate IE windows or one window with 4 buttons to change the IP addresses, depending on the stream you can use the WMP that we use in the video 6 menu. What type of streaming video ?
Re: IP Cam - set-up
Postby vaporhat on Tue Dec 01, 2009 4:57 pm
Wes, this is what I am trying to achieve in a single window in XL.
http://sv08msmedia2.dot.ca.gov/D7cam3
It would also be nice to also be able to stop the view on each camera though XL.
What's the best approach?
I was going to try and feed my video signal into a multiplexer and output the signal into a PCI capture card. Then set-up a server using abobe flash media server. http://www.adobe.com/products/flashmediaserver/
I do not typically use the playback unless I am looking for something and in that case I don't mind going back into the GeoVision software to dig that up. So I don't necessarily need that functionality in XL. Is there a better way to go about this or more efficent means of setting this up?
Open to all ideas..
gvmux16tc.pdf
(41.7 KiB) Downloaded 321 times
-3RiC
Return to Video Streaming
