Panasonic IP Camera User & Password
Video streaming sites and links to streams
Postby wesblack on Tue Sep 23, 2008 3:50 am
In xLobby V2, V3 the IP camera example menu uses the panasonic webcam, model: bb-hcm311. If you use Internet explorer 7 instead of IE6 then xLobbys command string needs to be interpreted differently and will not pass the user and password information correctly his requires a registry entry to make it work correctly.
Standard xLobby string: http://username:password@192.168.254.25 ... ion=TiltUp?
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_HTTP_USERNAME_PASSWORD_DISABLE]
"explorer.exe"=dword:00000000
"iexplore.exe"=dword:00000000
Re: Panasonic IP Camera User & Password
Postby nslmanu on Wed Aug 19, 2009 5:18 am
yop thanks for the tip/trick ...
i'll used it.
But my question is simple : where is the configuration point to setup IP cameras ?
Because only wecams i 've found but not Ip camera ...
Thanks in advance for your answezr.
Manu
nslmanu
Return to Video Streaming
