was the 'party mode' bug ever fixed?
Multizone Audio Control Systems, xLobby, Russound, Xantech
Postby CaM on Mon Jul 25, 2011 3:38 pm
hi, I use xlobby v3 for multi zone audio (winamp via soundcard) which works great.
I was never able to get a party mode working (i.e. 1 source played in multiple zones) as some zones would lag after a while
Was this bug ever fixed or is a hardware solution the only option?
If a hardware solution is needed, can anyone recomend a multi-zone audio switcher that is of high quality, works with rs232 and would not color the sound of my existing amps?
I would love the ADA Suite 8 x 8 but its probably out of my budget...
thanks
CaM
EDIT :
It turns out that the soundcard (RME + daughterboards) I have had for almost 10 years allow me to do this via software :)
CaM
Return to Multizone Audio
