xLobby Audio Codecs
Multizone Audio Control Systems, xLobby, Russound, Xantech
xLobby Audio Codecs
Postby wesblack on Sat Apr 12, 2008 5:53 am
Some users wanted information on playing different files in xLobby. Below are links to free codecs that will work with xLobbys internal music player. These are the default file extensions that Xlobby Ver2 will play without any need for additional codecs, mp3,wav,ape,wma,flac,ogg. Under F2, select Databases, Import and add the file extension you want to the field Extensions, this will enable xLobby to play them after refreshing or imporing your music.
.ape audio files,
http://www.free-codecs.com/RadLight_APE ... wnload.htm
Audio Codec Websites:
http://www.codec-download.com/
http://www.divx-digest.com/software/divxcodec.html
http://www.softpedia.com/get/Multimedia ... io-Codecs/
Return to Multizone Audio
