Insteon powerlinc controller which one?
Lighting control systems, upb, lutron, insteon, LED lighting, Etc.
Postby larryep on Wed Mar 30, 2011 12:16 pm
Hello
Which powerlinc controller works with the lighting service in xlobby?
I tried my PLC ( Item# 2414U) but had no luck with it. Should I purchase the newer PowerLinc Modem - INSTEON USB Interface (Dual-Band) Item# 2413U.
thank you
Larry
larryep
Re: Insteon powerlinc controller which one?
Postby wesblack on Thu Mar 31, 2011 2:07 am
The 2414U will work but it sometimes locks up or can become unstable. The 2413U is more reliable and should work well.
See this for guidelines using insteon technology. http://xlobby.com/news/2009/09/01/xlobby-insteon-setup-facts-and-information/
Postby larryep on Thu Mar 31, 2011 11:57 pm
Wesblack,
thank you for the quick reply. I will give the newer PLC controller a try.
does the houselinc software, the first release, interfere with the xlobbylighting service? Can running both at the same time, become problematic?
Larry
larryep
Postby smarty on Fri Apr 01, 2011 12:28 pm
larryep wrote: I will give the newer PLC controller a try.
....Wes is telling you to use the PLM controller, NOT the PLC type one....
smarty
Postby larryep on Sat Apr 02, 2011 3:11 am
Holy crap I did not realize there are 2 different devises! thank you for making me aware of that.
Uploaded with ImageShack.us
larryep
Postby larryep on Wed Jun 29, 2011 4:00 am
hello
i had my insteon devices working for about 3 months but the past 2 weeks the service is not working. Not sure why.
the xlobby lighting service just shows yellow dots. What port should the PLM be on?
none?
usb?
com1?
com4?
my xlobby app. in services shows port 9000 when I click on lighting service.
one more thing, I am not getting a cpu reading in xlobby any more also. :?
thank you
Larry
larryep
Postby stevenhanna6 on Tue Jul 05, 2011 2:56 pm
larryep, the PLM is a com port. The old PLC is a true USB device, the new one's just have a built in usb to serial controller, so when you plug it in I should have asked for a usb to serial port driver depending on the windows version.
Select the com port from the drop down. Close the settings box. Close the app and restart it. If it doesn't connect just change the com port again. The actual "test" button doesn't work so ignore that. If it's the USB model it's probably Com4.
Once you have the right com port your devices should have a green icon next to them.
I'll add that the lighting app is far from the easiest thing to use right now, I usually always have to login to help an installer set it up, it will become part of xlobby itself within the month if everything goes according to plan. In fact I plan on moving all service apps into xlobby to make them easier to use.
I've never used their 2413U, let me know if that's the one you are using, hopefully they didn't change the protocol again.
Postby larryep on Tue Jul 12, 2011 8:50 pm
thank you Steven com4 worked. :D
adding the services to xlobby sounds like a really good idea.
i am using the 2413u model.
larryep
Return to Lighting
Users browsing this forum: No registered users and 7 guests
