HVAC Climate Control Screenshot
Postby wesblack on Mon Oct 29, 2007 5:28 am
This is a peek into ver 3 HVAC climate control sample menu. Aprilaire among others will be integrated into xLobbys core in ver 3.
Re: HVAC Climate Control Screenshot
Postby sharp_1 on Mon Oct 29, 2007 1:55 pm
Looks great, what type of thermostat will you be using? I would like to see the specs on that too when you get a chance. Thanks!!
sharp_1
Postby cmhardwick on Mon Oct 29, 2007 3:25 pm
Same here and what connectivity would be required, etc. :)
Postby wesblack on Mon Oct 29, 2007 4:46 pm
Some APRILAIRE Products
http://www.iautomate.com/hvac.html
Postby smarty on Mon Oct 29, 2007 6:03 pm
Wes,
Hopefully you will also consider RCS (Residential Control Systems) http://www.resconsys.comin addition to Aprilaire. I think both are fairly popular with the home automation crowd.
As a side note, using the ElkM1 plugin, I have already designed a nice screen that controls and displays multiple Tstats and zones, but I bet the stuff you guys come up with will be a bit fancier.
smarty
Postby wesblack on Mon Oct 29, 2007 8:10 pm
Steve,
I looked at there website and the RS232 control codes , looks good to go for xLobby. I will contact them to purchase there thermostat and test it out. If we get something setup and working for ver 3 I will let you and the forum know.
Return to Announcements
