assign color to button or shape
Got an idea, post it here
Postby CaM on Thu Nov 17, 2011 11:38 am
Hi,
it would be nice if I could assign a color (via its hex form) to a button or a shape within an event.
Cameron
CaM
Re: assign color to button or shape
Postby gravy on Thu Nov 24, 2011 10:25 pm
I agree Cameron. I'd like to see that request extended to be able to change all properties of buttons and shapes via events.
I would like to set a number of button and/or shape elements (especially opacity) so i could mimic an Insteon lights dim level.
gravy
Postby PiDD on Sun Nov 27, 2011 5:29 am
yeah that would be perfect.. to be able to set a color or change a graphic by what the insteon light level is would be the pro level touch I am looking for.
Home Theater ....The never ending project!
http://www.pidd.ca
PiDD
Postby gravy on Mon Nov 28, 2011 7:53 pm
I had actually submitted this as a Mantis request too. Request 938.
Hopefully Steven or Wes can chime in with their thoughts on how hard this would be to implement? I think it has real value.
gravy
Postby wesblack on Tue Nov 29, 2011 12:10 am
Going over this with Steven again....will advise....! :)
Postby stevenhanna6 on Thu Dec 01, 2011 4:28 pm
xlobby->"button set opacity" command in latest bleeding edge
Postby gravy on Thu Dec 01, 2011 5:01 pm
Wonderful, thanks Steven!
I kind of hijacked CaM's request to set color via an event though. Is that possible to implement as well?
gravy
Postby stevenhanna6 on Thu Dec 01, 2011 5:35 pm
Shapes have a color value, but buttons don't. You can change the button image already there is a command for that, I could add a command to shape the color of a shape if that's what you want.
Postby PiDD on Thu Dec 01, 2011 6:52 pm
Thanks Steven,
Im playing with this now.
I added a circle graphic, a button and text box all with an ID = 'test opacity' and I made them yellow. (just to see what ones the effect will happen on)
I created a couple buttons.. one to set the opacity for 'test opacity' to 20 the other to 222.
When I try both buttons nothing happens?
What am I doing wrong?
http://www.pidd.ca
PiDD
Postby stevenhanna6 on Thu Dec 01, 2011 9:41 pm
you have to use a percentage like 5% or 70% or a variable, new build now shows that.
Postby gravy on Thu Dec 01, 2011 10:01 pm
stevenhanna6 wrote:Shapes have a color value, but buttons don't. You can change the button image already there is a command for that, I could add a command to shape the color of a shape if that's what you want.
Yes, please! I could make good use of this function too.
gravy
Postby wesblack on Thu Dec 01, 2011 10:53 pm
Example showing 7 Buttons that have individual events to set the bulbs opacity value. The menu has a light bulb image thats not illuminated, another image of the same bulb overlayed on top with the exact same x,y coordinates that using the Button Set Opacity event.
Sample Video+Screenshots
Video
[ Play Quicktime file ] xLobby Button Set Opacity Event.mp4 [ 348.71 KiB | Viewed 17291 times ]
Button Opacity Test Menu Screenshot 1
Button Opacity Test Menu Screenshot 2, skin editor showing the Button Set Opacity event.
Postby PiDD on Thu Dec 01, 2011 10:56 pm
Works great! This is too cool!
http://www.pidd.ca
PiDD
Postby PiDD on Thu Dec 01, 2011 11:14 pm
Can I tie the opacity level parameter in the event to the slider value variable?
So if my slider variable is %variable>xdimlevel% can I use that for my opacity? I think the answer will be yes but its not working for some reason??
http://www.pidd.ca
PiDD
Postby PiDD on Thu Dec 01, 2011 11:20 pm
arg sorry guys... just to answer my own question... yes, just add a % at the end. %variable>xdimlevel%
Thats twice that little % got me
Can I pass the button id of the button I mouse click to the button id parameter for the opacity command?
http://www.pidd.ca
PiDD
Return to Feature Requests
