Arcsoft TMT3 control
Got an idea, post it here
Postby Grooby on Mon Nov 30, 2009 3:10 pm
Hi Wes/Steven
I know we have native zoomplayer control which i use :D thanks...
...but any chance you can do the same for TMT3 for Bluray control from xlobby.
Ta
skinning for the fun of it
Re: Arcsoft TMT3 control
Postby billberet on Mon Nov 30, 2009 3:44 pm
hey groob
do you use zoomplayer instead of the native XL player?
if so, how do you like it?
i've been using the native player for everything, I would like to test out others.
Postby Grooby on Mon Nov 30, 2009 4:28 pm
Hi Bill
I've always used zoomplayer since i got into this HTPC lark...i just like all the bells and whistles it offers + i need reclock to change my movies from 25 to 24 fps for my pj and i could never get reclock to work with the native player.
It has a trial period so u lose nothing in giving it a go + u can control it direct from xlobby which is great!
Postby wesblack on Mon Nov 30, 2009 5:14 pm
Andy,
The current version of xLobby V3 works with TMT3 for Blu-ray playback.
http://www.arcsoft.com/EN-US/software_title.asp?ProductCode=TMT3P
Postby Grooby on Mon Nov 30, 2009 6:34 pm
deleted by Grooby
Postby Grooby on Tue Dec 01, 2009 3:42 pm
Found the news post...triggers...so can i associate the Arcsoft triggers to the zoomplayer controls as well in skin to keep just one player controls screen...if you follow
Oh and does TMT3 launch automatically when u press play or do i have to associate the player to a file format like the other players in setup?
Postby wesblack on Wed Dec 02, 2009 11:38 pm
Andy,
Look at the screenshot below. The file you need is in the trigger area of the skin editor under xlobby usbuirt remote. If you do not do a full update of xLobby then the file you need will not be included with default skin.
Return to Feature Requests
