95-1062 xLobby 300 ft. 4 Zone RS232 Hookup Diagram
Drivers and accessories
Postby wesblack on Wed Oct 01, 2008 4:32 pm
This setup is a basic 300 ft. 4 Zone RS232 serial Touchscreen setup for xLobby with mirrored video outputs. There is also some other prototype products we are experimenting with using a single xLobby machine with 4 VGA video outputs running 4 versions of xLobby with 4 touchscreens all assigned to each video output with the ability to control different menus in the xLobby interface. So each user in different rooms can do what they want. Shown below is what a system integrator would see if they do a remote desktop Log-Me-In session to access an xLobby machine with multiple interfaces running at the same time. I will have some more images and details of this new product concept soon.
95-1062 xLobby Interface Diagram RS232 300 ft.pdf
(189.98 KiB) Downloaded 347 times
More Information on Calrads 40-1010: http://www.calrad.com/download/40-1010.pdf
Re: 95-1062 xLobby 300 ft. 4 Zone RS232 Hookup Diagram
Postby vaporhat on Thu Oct 02, 2008 3:48 pm
Wes, are you getting 300 feet over rs232->CAT5?
If so, are some devices more sensitive to this distance then others?
-3RiC
Postby wesblack on Thu Oct 02, 2008 10:46 pm
Yes some devices may require higher speeds and this is where you run into distance issues. The Calrad touch screens are not very demanding and do not require high speed baud rates.
Return to Touchscreen Software and Hardware
