Control xLobby By RS232
Share and exchange RS232 codes here
Postby wesblack on Tue Mar 23, 2010 6:08 am
xLobby Communication Settings:
Bits per second: 19200
Databits: 8
Parity: None
Stop Bits: 1
Flow control: None
If testing with hyperterminal, ensure the folllowing settings are enabled.
“send line ends with line feeds”
“append line feeds to incoming lines ends”
“echo typed characters locally”
All commands will echo back with a “received:” string, with will
include the command that was sent with its parameters.
Protocol Commands
“trigger:rs232:”
The trigger rs232 command can be used to trip an rs232 trigger in
xlobby. You will pass the text you used for your rs232 trigger after
the “trigger:rs232:” command.
For example, in xlobby there are a series of basic triggers one such
trigger is “xlobby:goto menu” to trip this trigger we will have to
pass this text with the “trigger:rs232:” command as follows.
trigger:rs232:xlobby:goto menu
Also note a carriage return must be sent with the command.
“parse:”
The parse command allows you to pass a string which will then be
parsed by xlobby and returned with a “results:” string.
For example if you wanted to get the artist that is now playing you
can use the following string.
parse:%audioplayer>now>artist%
which would return the following if we had U2 playing.
parseresults:U2
any variable or text that is usually parsed within xlobby can be
parsed this way. If you send a string with non-variable text like the
following
parse:Album Name: %audioplayer>now>album%
it would return the following, notice how “Album Name:” has not been
touched since there is nothing to parse from it.
parseresults:Album Name: Joshua Tree
Current Triggers
trigger:rs232:xlobby:goto controls
trigger:rs232:xlobby:goto exit
trigger:rs232:xlobby:goto help
trigger:rs232:xlobby:goto movies
trigger:rs232:xlobby:goto music ambience
trigger:rs232:xlobby:goto music flow
trigger:rs232:xlobby:goto music generic
trigger:rs232:xlobby:goto music playlist
trigger:rs232:xlobby:goto music prism
trigger:rs232:xlobby:goto now playing
trigger:rs232:xlobby:goto pictures
trigger:rs232:xlobby:goto radio
trigger:rs232:xlobby:goto videos
trigger:rs232:xlobby:goto weather
trigger:rs232:xlobby:media player fast forward
trigger:rs232:xlobby:media player next chapter
trigger:rs232:xlobby:media player pause
trigger:rs232:xlobby:media player previous chapter
trigger:rs232:xlobby:media player rewind
trigger:rs232:xlobby:media player stop
trigger:rs232:xlobby:media player play
trigger:rs232:xlobby:music player fast forward
trigger:rs232:xlobby:music player next
trigger:rs232:xlobby:music player pause
trigger:rs232:xlobby:music player play
trigger:rs232:xlobby:music player previous
trigger:rs232:xlobby:music player rewind
trigger:rs232:xlobby:music player shuffle
trigger:rs232:xlobby:music player stop
trigger:rs232:xlobby:navigation back
trigger:rs232:xlobby:navigation backspace
trigger:rs232:xlobby:navigation down
trigger:rs232:xlobby:navigation enter
trigger:rs232:xlobby:navigation left
trigger:rs232:xlobby:navigation page down
trigger:rs232:xlobby:navigation page up
trigger:rs232:xlobby:navigation right
trigger:rs232:xlobby:navigation up
trigger:rs232:xlobby:volume master down
trigger:rs232:xlobby:volume master mute
trigger:rs232:xlobby:volume master up
Screenshot xLobby RS232 triggers in the skin editor
Re: Control xLobby By RS232
Postby lpg on Tue Mar 23, 2010 4:06 pm
now that is cool
Postby CaM on Fri Feb 18, 2011 11:20 am
hi, I am having trouble controling Xlobby via RS232.
I am going from my CG-12-100 via serial cable to my htpc.
I am trying to send the following string
"trigger:rs232:xlobby:goto menu\r"
Does this command look ok?
thanks
CaM
CaM
Postby wesblack on Fri Feb 18, 2011 3:19 pm
This feature only works in the commercial version of xLobby V3 and not the last working freeware version. :(
Wes
Postby CaM on Sat Feb 19, 2011 12:59 am
hi, I am using version 3.
I have a global cache unit that I am trying to use so that Xlobby can be controlled via ip.
i.e. GC-12-100 > serial RS232 > HTPC (xlobby)
Have you tried this before?
thanks
CaM
CaM
Postby CaM on Sun Feb 20, 2011 10:46 pm
hi, I also notice that if I have a com port that is already in use and xlobby tries to 'enable' it then xlobby will crash.
thanks
CaM
CaM
Postby wesblack on Thu Feb 24, 2011 12:13 am
"hi, I also notice that if I have a com port that is already in use and xlobby tries to 'enable' it then xlobby will crash."
Yes this was a bug and it's fixed with the latest bleeding edge update.
Wes
Postby CaM on Thu Feb 24, 2011 1:45 am
hi, thanks for fixing that.
I will reopen this thread in the global cache forum.
thanks
Cameron
CaM
Postby CaM on Wed Jan 04, 2012 2:24 am
Hi,
I can now control Xlobby via RS232.
CaM
CaM
Return to RS232 Control Library
