HDMI 4x2 switcher - Monoprice
Share and exchange RS232 codes here
Postby vaporhat on Tue Dec 08, 2009 3:59 pm
I have been trying to get the full 2-way rs-232 communication going although so far without success. :?
Is anyone else using this switcher? Can you post an example of the commands?
20090602102244_RS232-Command.pdf
(260.19 KiB) Downloaded 91 times
-3RiC
Re: HDMI 4x2 switcher - Monoprice
Postby wesblack on Tue Dec 08, 2009 9:56 pm
Oh not Monoprice........... :( Enough said.
We have a switcher that is 4 x 2 HDMI with RS232 on way control strings, realize most small switchers like this are one way RS232 commands or simple IR to control the switcher. Larger switchers usually have full 2 way communication with status. Call me if you want to discuss this further.
Postby vaporhat on Wed Dec 09, 2009 1:51 am
In the documentation that I posted it says "PC receive the matrix system data" and "PC send controls to matrix". My thought was that those were 2-way formats? I am far from an expert in this area so I could easily be wrong :( I should have bought a Calrad switch :(
In any case, it would be nice to finally have this piece of hardware under rs232 control, with out without receiving a status. But I am having difficulty. Someone please but me in check...
My interpretation of the command string is:
byte1, byte 2, byte, 3, byte, 4
Example on/off:
0x10:0xd5:0x7b
(I am not sure what byte 2 is? Possibly a 2nd command so you can set output 1 and 2?)
This is what I have and does not work :( I tried all sorts of variations. I also tried the xController program. I was able to connect, but that's about it.
-3RiC
Postby wesblack on Wed Dec 09, 2009 7:52 pm
I assume this is your switcher below. The best way to communicate with the switcher is to use the xLobby xcontroller.
Link:http://xlobby.com/news/2009/04/16/xlobby-xcontroller-uconnect/ using this method you can acheive full 2 way RS232 communication.
Let me look at this, busy getting ready for CES, I will post back more details when I have a moment so you can start testing.
Postby vaporhat on Wed Dec 09, 2009 8:09 pm
Wes, that's the guy!
I would love to understand more about xController. I have read thought he documentation and have been fumbling around with it. But I haven't been able to actually get any command to register back inside the command window using the switch. No issues establishing a connection.
Maybe I will pursue this further with one of my other components that also supports 2-way communication that I already have rs-232 control over.
Good luck at CES!! We can talk more about this when you get back and spin down a little ;)
-3RiC
Postby vaporhat on Fri May 21, 2010 8:16 pm
These are the rs232 codes for this switcher. Yeah I know it too me long enough.. but better late than never. I was seriously distracted by other tasks. For this switcher you do need a null modem cable (despite what monoprice told me).
On/Off
A1
A2
A3
A4
B1
B2
B3
B4
4x2 HDMI Monoprice.xml
(3.02 KiB) Downloaded 161 times
-3RiC
Postby vaporhat on Tue May 25, 2010 5:56 pm
If anyone was curious how you calculated the byte 2 (~order)
0x0
using win calc, Hex, Byte
00 Not = FF
01 Not = FE
02 Not = FD
If anyone figures out how to receive the 2-way status command, please post it up. It would be nice to get a status of the device for a more elegant integration.
-3RiC
Return to RS232 Control Library
