Yamaha/Receiver/RX-V1900 and HTR-6290/RS-232C
Share and exchange RS232 codes here
Postby samsonlov on Fri Oct 02, 2009 8:33 pm
Here I will post a selection of Yamaha control screens, and screen "elements" featuring all the correct Descret RS-232C codes available for the component mentioned in the subject of this post. Though you may not be using the exact same component, there is some overlap with Yamaha's RS-232C codesets.
This topic will include:
1. Setup instructions to get Yamaha RS-232C compatible equipment working perfectly with XLobby.
2. The latest instructions from Yamaha - these are currently being re-written by Yamaha - specifically for this purpose.
3. Screenshots of the new control screens.
4. Downloadable screen.xml, eventgroup.xml, and any custom image files used in the screen.
I hope others will find this useful, and perhaps start their own topics to share the manufacturer's codes and control screens they have created.
The syntax I recommend for the "Subject" of similar topics is:
"Manufacturer/Component Type/Model Number(s)/Control type (RS-232C or Serial/IR/X10/Insteon/Other).
Feel free to use anything I have posted for your own personal use. Please contact me prior to re-distributing any of my work for commercial purposes.
Enjoy,
Re: Yamaha/Receiver/RX-V1900 and HTR-6290/RS-232C
Reserved 1.
Postby samsonlov on Fri Oct 02, 2009 8:34 pm
Reserved 2.
Reserved 3.
Return to RS232 Control Library
