Check word - rs232
Share and exchange RS232 codes here
Check word - rs232
Postby vaporhat on Sat Aug 23, 2008 5:32 pm
I am trying to calculate the check word for one of my components and can't seem to figure it out. I have the answer for a few commands, which helps, but I can 't seem to replicate the same answer.
The full command string is, On: 50 43 53 45 4E 44 02 04 80 70 C0 3F 40 4F the check word in bold, the information command underlined.
What pairs should I be adding to get the check word? and should I have my calculator set to byte or word?
-3RiC
Re: Check word - rs232
Postby wesblack on Sat Aug 23, 2008 10:12 pm
Sorry I have not sent you the details or posted them here with calculating the checksum. If I have some time tonight I will post the details here on the forum.
Postby wesblack on Wed Aug 27, 2008 3:16 am
Postby vaporhat on Wed Aug 27, 2008 4:17 am
Wes, thank you. tricky stuff.. not so intuitive.
For anyone else .. you can use the calculator in XP.
View - Scientific
Hex
Byte
for example: Power On 80 70 C0 3F
check word 1st (0x80 ^ 0xC0) = 0x40 type in the calc. 80+C0 Or = 40
check word 2nd (0x70 ^ 0x3F) = 0x4F 70+3F Or = 4F
The calculator in rs22 Analyzer is quicker if you have a long list to do: 80,C0, calculate
I will post up the full list of command when I am done in the rs-232 section.
-3RiC
Return to RS232 Control Library
