Russound ST2-XM IR Codes
Calrad, WACI, Misc. Hex Code Format
Postby wesblack on Thu Mar 03, 2011 7:28 pm
Russound ST2-XM
Smart Dual Tuner w/ XM ST2-XM
Link to russound:http://www.russound.com/product_detail.php?i=1038
The ST2-XM gives you the best of both worlds: XM® Satellite Radio and classic AM/FM. Separate tuners make it easy to listen to different programs at the same time. The XM module gives you access to the vast selection of programs and near CD-quality sound offered by XM.
When the ST2-XM is used with a Russound RNET® multiroom system, the powerful RNET technology provides reliable performance and easy operation. The system's Smart keypads and touchscreens display the AM/FM station and the XM channel, artist, and song title in real time.
A member of the ST2 Smart Tuner family, the Russound ST2-XM is a high-performance source component in a compact single-unit chassis, ideal for virtually any multiroom system.
Standard FeaturesRNET® technology provides reliable performance and easy operation with Russound RNET system keypads and touchscreens
Six banks of six presets per tuner - 72 total presets - with customizable preset and bank names
Works with a wide variety of multiroom systems
Integrates with virtually any RS-232 control device
Dual tuners in a single-unit rack-mountable chassis
Includes rack ears, AM/FM and XM antennas, audio cables, power supply, and remote control
IR remote control Codes for use with xLobby:
(Russound IR)_Russound_ST2 Smart Tuner_ST2-RC.xml
(13.88 KiB) Downloaded 385 times
Shipping Dimensions 12.0" (W) x 4.0" (H) x 21.0" (D)
(30.5 x 10.2 x 53.3 cm)
Shipping Weight 7.1 lbs (3.2 kg)
Antenna Connection XM 50-ohm SMB
Antenna Impedance AM: 300 ohms unbalanced
FM: 75 ohms unbalanced
Communication Ports RNET link ports: 2 RJ45
RS-232 interface port: 1 DB9
Keypad ports: 2 RJ45
IR inputs: 2 1/8-inch TS
Frequency Response AM: 40 Hz to 3 kHz +/- 3 dB
FM: 30 Hz to 15 kHz +/- 1.5 dB
Image Rejection AM: 33 dB
FM: 80 dB
Optional accessory ST2-KP Smart Tuner Keypad
Power Requirement(s) 12VDC 1.5A separate power supply
S/N Ratio AM: 55 dBu
FM: 6 dB max 12 dBu
Sensitivity AM: 20 dB
FM: 30 dB
Signal to Noise Ratio AM: 45 dB
FM: 60 dB
Stereo Separation FM: 40 dB
Tuning Range AM: 530 to 1710 kHz
FM: 87.7 to 107.9 MHz
XM: 2332.5 to 2345 MHz
XM Channels 150
Return to IR Hardware and IR Code Library
