Pioneer HEX IR Codes (WACI)
Calrad, WACI, Misc. Hex Code Format
Postby wesblack on Sun Apr 01, 2007 2:05 am
Use this area to share Pioneer IR codes. A full database will be a available in the future for all the current IR codes for Pioneer and others manufactures.
Pioneer Receiver VSX-D906S:
Link: http://www.calrad.com/IR_Codes/Pioneer/VSX-D906S.wir
Postby Cabnetguy on Mon Apr 02, 2007 12:09 am
Hi,
Would you happen to have access to the IR codes for the Pioneer VSX-1015 TX?
I bought the receiver as a display unit and it didn't come with the remote.
Brian
Cabnetguy
Postby wesblack on Tue Apr 03, 2007 4:42 am
Cabnetguy
Look at this link. I think they have a CCF file on your unit or even a model thats close. Worth a look. I checked our database and we do not currently have this models IR codes available in hex.
http://www.pioneerelectronics.com/pna/v ... _262645248
Postby lpg on Mon Apr 23, 2007 12:47 pm
Cabnetguy wrote:Hi,
Call Pioneer Tech Support. I was able to get IR codes for my F07 DVD multichanger a few years back. Make sure you have some time to do it you will be on the phone a while. I remember that I needed to get to second level support to get the document.
Return to IR Hardware and IR Code Library
