I can not even get the basic up, down, left, right, enter, commands to transmit.
Please .. someone toss me a bone here
viewtopic.php?f=2&t=6140
sharp_1 wrote:Here is a screenshot from another thread question I helped with. Looks like the status windows stays blank. I think I remember someone saying that this was typical behavior.
Good luck!!
remember to use triggers in order to get your navigation buttons to work.
S Pittaway wrote:on the usbuirt forum there is a link to a little utiliy which lets you porgram the the wakeup buttons, it also shows you when its recieving data... i think its called something like lrnHelper.exe, if that is picking signals it looks like its wrong on the xlobby side, if not maybe the urit is faulty.
also when you learn the codes into xlobby, make sure you are close (10 cm) to the uirt box, it seems to learn much more efficently when you are closer.
assuming you have learned the codes corectly do anything haapen while the ir plugin window is open when you press one of the remote buttons?
and last but not least, you have added up, down etc to the plugin but have you linked then to any events in the event tab?
sharp_1 wrote:You need to learn those up, down, left and right commands into xLobby before anything else.
Step 1: Select the "(xlobby) xlobby - xlobby - xlobby" device under the IR plugin module and learn the IR commands for each of the navigation events.
Illustrated:
Step 2: Connect your new IR commands to the navigation events.
Illustrated:
Good luck!!
vaporhat wrote:When you learn codes, does it need to reach 100% to accept the IR input?
sharp_1 wrote:vaporhat wrote:When you learn codes, does it need to reach 100% to accept the IR input?
Yes
vaporhat wrote: I am still a little foggy on how I translate keyboard commands into IR commands.
sharp_1 wrote:vaporhat wrote: I am still a little foggy on how I translate keyboard commands into IR commands.
I never have used this plugin but I believe it will do what you are asking:
XLHotkey: A plugin that allows a user to assign keys to buttons or events. Functionality overlaps partially with the triggers of events, girder and adds some functions of its own. Download XLHotkeyPlugin.zip
vaporhat wrote:I really just want to be able to use my MX-3000 remote to scroll though my music/DVD's and select albums and such.
sharp_1 wrote:Now that I'm thinking about it...what do you mean by keyboard commands??? if you're not going to use a keyboard???
