Calrad - Xlobby Multizone Amplifier Card
Systems, Graphic Cards, Wireless Devices
Postby wesblack on Sat Jul 28, 2007 4:35 am
We just received some of our first prototype xLobby Class D Amplifier cards and are working on adding some additional features. The purpose behind this card is to do single or multizone audio directly from a Client or Server based xLobby media unit without using external amplifiers. Input to the card can be a direct analog signal or a assignable USB digital signals. The reason for the analog input is so that external audio sources can be selected using external xLobby controlled audio switchers providing not only xLobby's audio source but sources from other audio devices as well. Also using a 5.1 or 7.1 sound card, audio can feed up to 3 or 4 stereo zones of audio using these card's. The USB digital input act's as a single zone audio sound card and xLobby can assign zones directly to them.
Now xLobby can be a stand alone system for small area's without an external amplifier or receiver. We have some other class D amplifiers, still in development that can be located inside the chassis that will deliver up to 60 watts per channel.
We will have these card's at the Denver Cedia show in September.
More details on the show here: http://www.xlobby.com/news
xLobby Digital Amplifier Card---Class D
Detailed Product Description
Features:
95% power efficiency
Uses internal PC power supply for power
On\Off Power Switch, Seperate L.E.D power indicator
-Supported sound sources.
Pure digital USB signal input
Analog 3.5mm Stereo Audio signal line in
S/N Ratio : 93dB & up
24 bit / 96K Hz Stereo A/D converter
-Audio Line Inputs:
1. Sound source from computer internal USB Digital signal from motherboard
2. Audio amplifier line in priority detection over USB sound source
-Output Power: 2 x 16W (full 4 Ohm)
Re: Calrad - Xlobby Multizone Amplifier Card
Postby CharmQuark on Sun Sep 02, 2007 1:46 am
Hallo W,
when I read your post I was reminded of the problems I encounteed in the past several times.
This is exactly where I got stuck about a year ago; finding software that was able to manage multiple audio devices simultaneously and independantly of each other.
My goal was finding a way to run multiple HTPC programs that could be operated independantly of each other. Each program has it's own control through Girder software, Gyration remotes and own video and audio output. Serving 4 'rooms' with independant video was quite easy, in possesion of two dual head Matrox Pharelia cards there're several options. It was the handling of the multiple independant audio sources at the same time, within the somewhat just-over-the-avarage-family-multimedia-pc budget, where I got stuck and I had to put the whole project on hold.
To make a short story long and recap whether I got it right:
a. With these mods to xLobby, will I be able to run multiple media programs (MediaPortal,Vista MC and xLobby) on one machine and manage their audio simultaneously and independantly of each other with xLobby?
b. If no, would it be possible to manage several virtual machines and assigning them to these indepenant outputs?
c. If none, what then?!
One way or the other, I really appreciate your post, it's always nice to see that there is always someone out there doing a better job!
Regardless of the answers to the questions above, I want to thank you and eveyone else beforehand for putting effort in this. It's because of exactly this way of networking that internet is what it is nowadays. As long as there's this kind of customization there will be people wanting it!
Oh yes, do you happen to know what the price may be and where I can order it?
cheers,
Quark
CharmQuark
Postby P3rv3rt B3ar on Sun Sep 02, 2007 2:10 am
CharmQuark wrote: It was the handling of the multiple independant audio sources at the same time, within the somewhat just-over-the-avarage-family-multimedia-pc budget, where I got stuck and I had to put the whole project on hold.
Many people here (yours truly included) done it ever since Adam was created with less than 5$ ebay iron. Search post about kX drivers...
PS parhelias are triple heads ;)
Postby wesblack on Sat Oct 20, 2007 4:31 am
40-ZA1 Multizone audio literature available.
PDF Document Download: http://www.calrad.com/download/40-ZA1.pdf
Postby PhilB on Sun Oct 21, 2007 3:43 pm
Wes,
Is this item available for sale yet?
PhilB
Postby rberger3 on Wed Nov 21, 2007 4:32 am
Any news on this?
rberger3
Postby rberger3 on Thu Dec 13, 2007 7:26 pm
Bump!!
rberger3
Postby wesblack on Mon Jan 21, 2008 4:03 pm
This unit is in stock.
Postby rberger3 on Mon Jan 21, 2008 4:42 pm
I can't find it on your site. Also, I tried contacting a local distibutor http://eskc.com/default.asp and they don't have them. Any thoughts?
Thanks WES
rberger3
Postby sharp_1 on Mon Jan 21, 2008 6:02 pm
I think Wes would like you to call Bob Adams on this.
Email from Wes regarding the multizone hardware:
"If you want to order these, please contact Bob Adams at bobadams@calrad.com or Tel: 323-465-2131."
sharp_1
Postby defrag on Sat Apr 19, 2008 8:41 am
Wes,
I have emailed you and Bob several times over the past few weeks on availability and pricing for this and have yet to recieve a reply. Could you please respond?
My HTPC
defrag
Return to xLobby Hardware
