crash on rebuilding thumbs on latest bleeding edge build
Postby S Pittaway on Fri Oct 14, 2011 8:16 am
Mantis: 0000970
Select rebuild thumbs from the setup menu...
Xlobby restarts...
Loads databases etc...
Screen shows ------- and xlobby crashes.
This is on the latest bleeding edge build (did not make a note of the number so just just the top one).
Rolled back a few versions and it rebuild the thumbs without crashing but the images used by the skin database(s) are not added (this was a bug from ages ago).
Re: crash on rebuilding thumbs on latest bleeding edge build
Postby wesblack on Fri Oct 14, 2011 3:07 pm
Looking at the issue...thanks Sean
Postby wesblack on Fri Oct 14, 2011 6:02 pm
Bug confirmed, fixed on the latest bleeding edge release.
Postby S Pittaway on Wed Oct 19, 2011 10:51 am
cheers.
Postby S Pittaway on Fri Oct 21, 2011 4:27 pm
Wes,
the crash is fixed but if you are not on the default skin it still does not cache the images used in the skin databases.
Postby S Pittaway on Tue Oct 25, 2011 2:19 pm
Ill expand the second bit:
I am not using the default skin i use my own...
The menu database is stored in the skin directory and the coverart is shown on my menu screen.
When i do a rebuild on the images nothing shows up for the menu.
This was a bug ages ago (not long after V2 started) and you fixed it, something seems to have crept back in.
Postby S Pittaway on Fri Nov 11, 2011 12:49 pm
Bump, This is quite anoying none of the menu images show up in my skin...
Postby S Pittaway on Wed Nov 16, 2011 10:40 am
Not sure if you guys ever watched the Fast Show, but...
"Ill get my coat" :(
I swapped PC's and reinstalled (this was how i spotted the rebuild thumb bug) and i assumed the missing menu covers where caused by the same thing, But the install paths where different.
Changed my database to use skin://buttons and it started working.
All my fault, sorry for messing you around.
Postby wesblack on Wed Nov 16, 2011 4:16 pm
Glad you solved the issue....! :)
