navigation/hashcode problem?
Postby S Pittaway on Sun Feb 13, 2011 7:39 pm
i seem to have a problem overriding the navigation setings on a few of my screens, i setup nav left/r/u/down but when i actualy cursor around it ignors the settings...
i had a dig and it looks like i have a load of controls with the same hashode - not sure what caused it.
is there an easy way to sort it? and is it te hash messing up the nav?
Cheers, Sean.
Re: navigation/hashcode problem?
Postby stevenhanna6 on Mon Feb 14, 2011 5:03 pm
You're right, I uploaded a new bleeding edge. Copy and pasting would reuse the old hash code, which is wrong. I've also added a new button under the navigation settings so you can set the button hash manually, that's what you will have to do for the ones that have the same code.
Postby S Pittaway on Tue Feb 15, 2011 7:31 am
cheers.
