Rock TV doesn't work
Postby smarty on Fri Jun 04, 2010 11:38 pm
It appears that ROCK TV has changed.....my skin nor the default skin can tune into the different genres. The Rock TV website still appears to be alive and working.....
While I can make the URL snooper that Wes posted work, I am unsure how to "fix=up" the local button event (what IP address to change it to.....I do know how to edit local button events) :)
smarty
Re: Rock TV doesn't work
Postby wesblack on Sat Jun 05, 2010 6:44 pm
I will look at it on Monday.
Postby wesblack on Mon Jun 07, 2010 5:47 pm
Ok...........it's fixed. In the current release of xLobby V3 goto the setup menu, under the (Update) tab select (Advanced) under the Package ID enter rocktv and select the get button, next select (Install Updates).....you should be good to go again. :D
Postby smarty on Mon Jun 07, 2010 8:39 pm
Edit...
Spoke too soon....
tried the above instructions, but there is no package to install.
smarty
Postby lar282 on Tue Jun 08, 2010 11:44 am
wesblack wrote:Ok...........it's fixed. In the current release of xLobby V3 goto the setup menu, under the (Update) tab select (Advanced) under the Package ID enter rocktv and select the get button, next select (Install Updates).....you should be good to go again. :D
Does that work with ANY skin or will the above instruction only download a skin file in default?
Can anybody that uses the new skin post the new url please -:)
Postby wesblack on Tue Jun 08, 2010 8:00 pm
Sorry, Ok.......the Package ID (rocktv) is now available for download. The file is for the default skin, you can copy the events and use them in any skin you want.
Postby smarty on Tue Jun 08, 2010 11:02 pm
OK, I was able to download the RockTV package, and i did the install......but...I still have the same URL info in the local event (at least for the one button that I investigated).
Something is still amiss here....
smarty
Postby Jay on Thu Jun 10, 2010 12:47 am
also
Postby stevenhanna6 on Thu Jun 10, 2010 6:03 pm
download "rocktv" package again, it was unzipping to the wrong folder.
Postby Jay on Fri Jun 11, 2010 3:43 pm
Back up.
Postby smarty on Fri Jun 11, 2010 4:56 pm
yep....works now!
Thanks!
smarty
