xlobby at idle using 26% of my Q8400 cpu
Postby CaM on Fri May 07, 2010 11:08 am
Hi, when xlobby first starts it uses very little processing power - somewhere between 0 - 4 % of my Q8400 cpu.
After a while xlobby jumps to around 26-30 % of my Q8400 cpu.
Has anyone else spotted this issue?
thanks
CaM
p.s. I have already entered this in mantis (0000837)
CaM
Re: xlobby at idle using 26% of my Q8400 cpu
Postby smarty on Fri May 07, 2010 12:49 pm
Not seeing that....
Can you try to selectively turn things off (disable plugings, Xlobby processes, timers, etc) to try to find the culprit?
smarty
Postby CaM on Fri May 07, 2010 10:14 pm
hi, I used to occasionaly get this issue with Xlobby 2 as well.
I will try and narrow it down; my guess is the issue is related to either sound or events.
thanks
CaM
CaM
Postby lar282 on Sat May 08, 2010 6:51 am
I actually got that prob yesterdays and when I removed the music.xml all was ok. So I removed the cache directory and let xlobby rebuild it. Now it's back to normal
Postby CaM on Sat May 08, 2010 11:18 am
Hi, I will try deleting the xml / cache and see what happens.
Restarting xlobby has been my only fix so far.
thanks
CaM
CaM
Postby CaM on Wed Jun 09, 2010 4:52 pm
hi, I removed the XReceive plugin and my cpu usage dropped down to normal levels (1-6%). :D
Everything seems fine now.
thanks
CaM
CaM
