Server issues with databases
Postby Grooby on Tue Feb 09, 2010 10:52 pm
I have an unRAID server with all my media which feeds my xlobby machine. The problem i have is that xlobby keeps seeing all my media as "off line" everytime i fire it up. I have to re-import all the data in the databases for it to play music/movies.
Any ideas what is going on?
Andy :(
skinning for the fun of it
Re: Server issues with databases
Postby CaM on Tue Feb 09, 2010 11:25 pm
Hi, I am getting the same issue.
It seems I have to not only WOL but also open up the network folder for it to work.
CaM
Grooby wrote:Hi
Andy :(
CaM
Postby Grooby on Wed Feb 10, 2010 10:34 am
Wes?
Postby lar282 on Wed Feb 10, 2010 12:34 pm
Grooby wrote:Hi
Andy :(
Do u fire it up from cold, or is it different in standby/hibernate?
Do u map drives or use unc path?
Try this:
start computer
delay start of xlobby with 30 sec, then see if it works. Could be the network is not ready when XL starts. Same goes for hibernate and stuff, then u need to touch the drives. I run a bat file on resume automatically to DIR /s the mapped drive..
Postby Grooby on Wed Feb 10, 2010 3:12 pm
Had a word with one of our IT guys, gonna try not using mapped drive short-cut and try to use "\\" for a direct link to server folders. (also suggested by Lars)
EDIT
Ok i think i have fixed the problem, i had pointed to the mapped drives in "my computer" rather than through "my network". I have changed it by linking to media through "my network" \\... seems to be working (so far, fingers crossed)
Postby billberet on Wed Feb 10, 2010 6:38 pm
you should be ok,
i use the \\ method as well, works great with server and clients.
Postby CaM on Wed Feb 10, 2010 10:59 pm
Hi, I use to use \\ for my access but found I had suspend issues in Xlobby.
I now use drive mappings, with allows me to work on my other suspend issues with Xlobby.....
CaM
billberet wrote:you should be ok,
CaM
