Spider Cover Save
Spider Cover Save
Postby Grooby on Sat Jan 30, 2010 5:49 pm
Can anybody confirm that covers are not being saved in latest version.
skinning for the fun of it
Re: Spider Cover Save
Postby PhilB on Sat Jan 30, 2010 11:08 pm
I just saved 2 DVD covers no issue with ver 3.0.10023.2. However, I was using the F2 database spider, not the events. Check that?
PhilB
Postby samsonlov on Sun Jan 31, 2010 1:07 am
(Build 3.0.10028.45)
Looks like a bug to me. - I just tried it with the latest build on the default skin and movie covers wouldn't update through the DB Editor.
Posted in Mantis - Issue #0000788
Postby Grooby on Sun Jan 31, 2010 11:53 am
Thanks, worried it was my system for a minute.
Postby Grooby on Mon Feb 08, 2010 8:41 am
I just tried the latest build, trying to save covers from within the skin in manage/spider(not alt/F2) still does not work for me.
Anybody else have this problem?
Postby billberet on Mon Feb 08, 2010 5:34 pm
i have the latest build on one of my clients and i did a spider of covers with no issues, saved the image.
this was with the default skin.
Tonight i will install the same build on my server and try a spider cover directly from there.
this will be on a custom skin.
**update**
i installed latest, did a dvd spider from the server, and it downloaded the cover.
no problems
the client had the new cover art as well.
Postby Grooby on Tue Feb 09, 2010 8:45 am
Bill, thanks...sigh...clean install me thinks...
Postby billberet on Tue Feb 09, 2010 4:26 pm
sorry for the bad new
yea a fresh install couldn't hurt.
or maybe the xml spider pages got corrupted, if you can copy them from another machine and
try again, before you do a fresh install.
could be the database too.
can you spider from the music pages?
when you refresh the music collection, do you get new coverart?
Postby Grooby on Tue Feb 09, 2010 4:39 pm
Vista main HTPC is the problem, i think i will copy the spider events from default skin into my iphone skin and see what happens.
I'll try the music spider idea...good one
I'll also try on my XP test machine and see what happens
****FIXED*****
