update crashes xlobby
Postby S Pittaway on Thu Dec 31, 2009 10:36 am
if i press any f the butons on the update tab, xlobby bombs out.
i am runing on xp sp3, windows firewall is off, avg anti virus, xlobby 4 dec build.
i used to get a bit more info when it crashed but at the moment it simply shows me the serious problem dialog.
i wil stick an enrty in mantis when i get a chance.
Re: update crashes xlobby
Postby capecodscot on Thu Dec 31, 2009 2:26 pm
I am Having exactly the same issue. Running Windows 7.
capecodscot
Postby stevenhanna6 on Thu Dec 31, 2009 7:11 pm
For both of you, when you hit check for updates it crashes? you don't even see it say "system is up to date" , and if that works when you hit install updates you should see it downloading the updates...you don't see that either?
did updates ever work?
capecodscot wrote:I am Having exactly the same issue. Running Windows 7.
do you have UAC enabled? try running xlobby with admin privileges
Postby S Pittaway on Fri Jan 01, 2010 7:04 pm
nope, for me i simply hit update and it crashes.
i have tried the update button a few times on older versions and they drashed as well, i assumed it was work in progress back then.
cheers, sean.
Postby capecodscot on Sun Jan 03, 2010 11:23 am
UAC is disabled and it is running under admin privileges. I will try on another machine and see if it replicates.
Happy New Year.
capecodscot
Postby stevenhanna6 on Mon Jan 04, 2010 6:22 pm
what happens if you do a new install or a keep and install to a completely new directory, fresh new install no content loaded, what happens if you hit the update button?
Postby S Pittaway on Mon Jan 04, 2010 7:14 pm
i treid removing my install, deleted the xlobby dir (just in case) and did a clean install using the 4 dec build and it was the same.
i can try the new release if its likely to be any differant, but it will probably be tommrow night before i get chance.
Postby capecodscot on Mon Jan 04, 2010 7:44 pm
Ditto.
capecodscot
Postby S Pittaway on Mon Jan 04, 2010 8:48 pm
fyi, i had a fw mins spare so i tried the new release... same result, it crashes.
its always nice to be running the currrent release when comlaining about somthing not working :)
Postby CaM on Mon Jan 04, 2010 10:08 pm
hi, it also crashes for me.
thanks
CaM
CaM
Postby S Pittaway on Tue Jan 05, 2010 7:17 pm
the new exe works great thanks.
Postby CaM on Sat Jan 09, 2010 5:57 am
Hi, I can now update with the latest build.
thanks
CaM
CaM
