Keep Aspect Ratio / Auto Repeat Checkboxes Acting "Funny"
Postby samsonlov on Mon Dec 28, 2009 11:00 pm
There seems to be an issue with the "keep aspect ratio" checkbox:
When I "tick" the keep aspect ratio checkbox for an item or a category (It doesn't work on category items by the way),
the "keep aspect ratio" checkbox gets UNticked, and instead, the "autorepeat" checkbox is ticked upon restart of XLobby.
Buttons and images other than "category>pictures>originalcoverart" (which always keeps original aspect ratio) and "category>pictures>cover" do not appear to respond to the "keep aspect ratio" option.
I tested with the following results:
For a given button or image except as described above; whether or not the thumbs and cache are deleted during restart process:
Ticking "keep aspect ratio":
Upon restart the "keep aspect ratio" is UNticked, and "auto repeat" is ticked.
Ticking "auto repeat":
Upon restart, "keep aspect ratio" is UNticked, and "auto repeat" is ticked.
Ticking both "keep aspect ratio" and "auto repeat":
In picture viewer, the aspect ratio seems to now be "preserved" due to new variable "category>pictures>originalcoverart", but there is still the issue with the checkboxes, and autorepeat keeps "self-ticking"
Has anyone else observed this?
Thanks.
(Added a note to Mantis Issue #0000510)
Re: Keep Aspect Ratio / Auto Repeat Checkboxes Acting "Funny"
Postby S Pittaway on Wed Dec 30, 2009 4:33 pm
i cant try it :) the auto update always crashes when i press the cheeck for updates butoon...
running on the 4 dec build...
