wes, question about trailers
Postby billberet on Mon Jun 22, 2009 12:00 am
hey,
it's been a while since i've asked about the trailers.
has the trailer feature been added to the ta-do list.
i finished creating my trailer and i want to play the trailer before the movie starts.
thanks again
-bb
Re: wes, question about trailers
Postby wesblack on Mon Jun 22, 2009 5:05 am
Bill,
Yes its on the list, I will discuss this issue on on Monday to see if we can get it done for the next release.
Postby billberet on Tue Jun 23, 2009 4:09 pm
tell me what you think
here is the trailer i created to play before each movie. i have several in development, but this one i think is finished.
http://www.cyberdyne-sys.com/upload/trailer.mov
Postby lar282 on Wed Jun 24, 2009 6:21 am
wesblack wrote:Bill,
Does this mean that even if you use the internal player one can use the
start event
stop even
end event
like we have when we use external player?
If so, GREAT....
Postby vaporhat on Wed Jun 24, 2009 1:59 pm
BB, great job on the trailer!
What program did you use to create it?
And aside from the DD trailer that you incorperated into yours, did you start with any stock video clips? if so, did you find them on a site similar to stock photos?
-3RiC
Postby billberet on Wed Jun 24, 2009 4:15 pm
watch it again, i made some updates to the trailer. let me know what you think
i use adobe after effects with a ton of plugins.
Self taught.
my only stock footage was the dolby digital.
the bouncing lens flare, lighting effects, spinning and burning globe, text, sounds are all mine i made from scratch.
the best output is the MOV files, but i cannot get it to play in XL.
can you play the mov file in XL?
i can export the movie as avi, but it's over 100 megs, while the mov file is 12 megs, BIG DIFFERENCE!!!!!
Postby billberet on Thu Jun 25, 2009 4:01 am
ok i got some comments about the trailer and i uploaded a new version, same link.
try it out and let me know what you think.
Postby billberet on Thu Jun 25, 2009 4:02 am
hey Wes,
did you ever have any luck playing MOV files inside XL.
i'm thinking of moving to cyberlink dvd 9, they now play MOV files.
i ran a plugin that plays mov files inside windows media player, works great.
but inside XL, i still can't get the mov file to play.
any suggestions?
Postby wesblack on Thu Jun 25, 2009 5:58 am
Bill,
I downloaded several WMP plug-ins to play .mov files and it prevented me from any playback in xLobby, windows media player worked fine. The reason xLobby has issues is because the .mov file format is subject to change by apple and the direct show player xLobby uses may play some files correctly while others will not. The WPF player we use in the video 6 menu should work on these files but this does not help you with playback of your file before a movie begins. Maybe the best solution is to convert the .mov file to a format that xLobby can play.
Postby billberet on Thu Jun 25, 2009 3:04 pm
yea i think i'm with you on that one.
too bad because the quicktime runs smoothly.
guess i can convert it to mpg.
thanks again
Postby billberet on Thu Jun 25, 2009 3:13 pm
hey Vapor, i finished my trailer and i went to production. click the link and let me know what you think.
i think it looks more professional now.
Postby billberet on Thu Jul 02, 2009 6:19 pm
Postby vaporhat on Mon Jul 06, 2009 2:55 am
Fantastic work BB!
-3RiC
Postby Marbles_00 on Wed Jul 08, 2009 1:37 pm
Yeah, pretty cool stuff. Are you for hire :?: :wink:
Postby billberet on Wed Jul 08, 2009 5:21 pm
what did you have in mind?
want me to change all the -bb's world to
MARBLE MADDNESS!!!
