Nokia 770 tablet and V3 Web server.
Postby Jay on Sun Feb 15, 2009 2:03 pm
Mapping appears to be scrambled. Taping various icons on the menu page shows the pointer on the server screen appearing at the same coordinates. Subsequent logons may see the pointer at a different spot. Or not. For some reason, weather icon wil launch that screen even though the pointer is no where near it. Hitting buttons on the weather screen only refreshes the screen and usually the Update button will activate even though it wasn't touched on the 770.
After the WX screen comes up, I can't go anywhere else.
Skin is the out-of-the-box Simplicity. The 770 works fine on the free ver. and worked fine on ver. 2 after a tweak by Stephen (you had to refresh after clicking an icon).
Re: Nokia 770 tablet and V3 Web server.
Postby Jay on Fri Feb 20, 2009 6:46 pm
Wes, did you get a chance to try the 770 you have with V3?
