DVD Profiler V 3.5
DVD Profiler V 3.5
Postby bryeden on Wed Dec 31, 2008 4:25 pm
Is there a problem with V3 and DVD Profiler Ver 3.5? When I attempt to put in the location of my .xml file under movies options in the movies template then xlobby closes down.
bryeden
Re: DVD Profiler V 3.5
Postby Bill Lott on Sat Sep 12, 2009 1:46 pm
Anyone using DVD profiler 3.5 with xLobby successfully?
If so, what are your DVD profiler settings in the xLobby database structure? I have the same problem as above. This used to work; not sure what I've changed.
Any help is greatly appreciated.
Thanks.
Bill Lott
________________
Now Playing: Image
Bill Lott
Postby Bill Lott on Fri Sep 18, 2009 12:23 pm
... bump.
Bill Lott
________________
Now Playing: Image
Bill Lott
Postby Bill Lott on Mon Sep 21, 2009 10:11 pm
Based on no responses, I'll make an assumption that this feature no longer works.
Would moving my movie files to ANT and using the xAnt plugin work? Can anyone confirm that they have xAnt working properly with Version 3 of xLobby?
I'm kind of between a rock and a hard place as I have 450 plus DVDs using a DVD jukebox and now I have 50 plus movies that I have saved to the hard drive. xLobby does a great job of copying the movies and storing them to the hard drive; but I still want to add DVDs to the jukebox and need some way to get the DVD info (including disk number) into xLobby. This used to work using DVD Profiler.
Thanks.
Bill Lott
________________
Now Playing: Image
Bill Lott
Postby stevenhanna6 on Tue Oct 06, 2009 9:17 pm
try the latest version posted 3.0.9279.6, I remember fixing the crash bug that was described above, don't know when though.
Postby Bill Lott on Wed Oct 07, 2009 2:21 am
Thanks Steven. I'm traveling for a couple days but will try it as soon as I get home.
Bill Lott
________________
Now Playing: Image
Bill Lott
Postby Bill Lott on Thu Dec 24, 2009 3:55 pm
Still having trouble importing DVD Profiler info.
Does anyone have this working correctly? Can you post screen shots or list how you set up the import in xLobby?
Greatly appreciated. Merry Christmas to all.
Bill Lott
________________
Now Playing: Image
Bill Lott
Postby stevenhanna6 on Wed Jan 06, 2010 11:28 pm
I dont have dvd profiler installed anymore, but this is what you have to do
1. open setup
2. goto databases
3. click "templates"
4. click the "movies" template from the list
5. click "movies options"
6. now you should see the dvd profiler settings
7. dropdown import list select "all"
8. import from, leave blank
9. folder, this is the location to your root dvdprofiler folder, something like c:\program files\dvdprofiler
10. xml, this is the location to the xml file you outputted from dvdprofiler
Postby lpg on Wed Jan 13, 2010 3:37 am
I have 3.5 also but have not been using it to feed xLobby for a while so I gave it a shot. It does not seem to update covers but loads the plot info and format tags, rating info and a few other fields. It would be great if it loaded what format the movie was in, Blu-Ray, HDDVD or DVD.
If you want me to detail what was loaded let me know.
Larry
