XAnt only works if in the Program Files directory?
Postby Marbles_00 on Fri Jun 04, 2010 12:21 am
I ask this as I'm trying out a new skin. Up to now I've only been using WinXP, but I do have xlobby on a Win7 machine in the C:\ root. It will not work in the Program Files directory. Though it all loads, I've noticed that it does not update via XAnt. I've double checked my paths in the XAnt.ini file, and I'm pretty confident I have everything setup right.
If the French Team is still around, or fractions of you still here, can this be modified to work from within the root directory (c:\xlobby\plugins) as oppose to the traditional c:\program files\... ?
Thanks in advance.
Users browsing this forum: No registered users and 10 guests
