how do i get a butons text from its id?
Postby S Pittaway on Sun Jan 31, 2010 7:34 pm
i wand to write a plugin command that would refresh a database, wait for the importstatus text to say scan completed, then do so other stuff...
but i have to admit that i cant see how to get the text of a button if i know its ID, am i missing something?
how do i get the text from importstatus into my plugin?
cheers, Sean.
Re: how do i get a butons text from its id?
Postby kris on Sun Jan 31, 2010 10:01 pm
you would probably have something like this :
if (xhelper.ConvertVariables("%importstatus>percent%") == "100%")
//do your thing
hope this helps, kris
kris
Postby S Pittaway on Mon Feb 01, 2010 7:47 pm
i was trying to the Status: xxx text to tell when it was complete...
the the 100% works great (and is a lot easier)
cheers, Sean.
Postby P3rv3rt B3ar on Wed Feb 03, 2010 6:31 pm
Pitt, if u r interest about general solution, theres a l33t h4x0r way of doing it, kinda "we dont need no API"-aproach... if i remember right theres a little caveat though, aproach doesnt work with proper buttons but only with text fields. This semantic differense obviously does not play any role as long as u can craft the skin by yourself.
XPluginSDK.Button OurTextBox=SDKhelper.getButton(ID);
//next lets use toString to make XL leak
String notFinal=OurTextBox.toString();
//little trimming required
String finalAnswer =notFinal.Substring(6,notFinal.Length-7);
// have fun ;)
