xTVDB
Re: xTVDB
Postby scottw on Tue May 12, 2009 1:23 am
badubo wrote:Same link :
you can now use <Series.XXX> or <Season.XXX> in the episode template (or <Series.XXX> in the season template) to access the data
i.e. :
<Series.coverart> will display the banner of the series
Hope this help
Awesome!!! Will try it out as soon as I can.
Thanks!!!!!
Scott
Re: xTVDB
Postby scottw on Tue May 12, 2009 1:09 pm
Badubo,
Sorry I am apparently a little slow this morning. Could you give me an example of how the episode template would look with the Series cover added to it, I am just not getting it :?
Scott
Re: xTVDB
Postby badubo on Tue May 12, 2009 4:22 pm
sorry,
I gave you the wrong variable :
it is <Series.cover> and not coverart, sorry
so you add a line :
seriescover=<Series.cover>
under the [template_episode] section
Badubo
Member of XLobby FR Team
badubo
Re: xTVDB
Postby scottw on Wed May 13, 2009 12:25 am
badubo wrote:sorry,
so you add a line :
Works PERFECTLY....thank you so much!!!!!
I really appreciate you updating this just for me even though others can use this feature.
One question I have and maybe you can help me but how can I do a search page for these TV shows. I want to be able to type in part or all of an episode title just like you can do with music or movies. I have search pages for music, movies and games but cannot get this working :?
I posted on this already here: http://www.xlobby.com/forum/viewtopic.php?f=6&t=6832&hilit=search
but nothing has worked so far.
Any ideas??
Scott
Re: xTVDB
Postby badubo on Wed May 13, 2009 1:16 pm
did you try to create a filter, then using an abc overlay, it must show the titles that contains the string you enter.
Badubo
badubo
Re: xTVDB
Postby scottw on Thu May 14, 2009 11:38 pm
badubo wrote:did you try to create a filter, then using an abc overlay, it must show the titles that contains the string you enter.
I got it...not sure why I had so much trouble. I decided to start over from scratch and it worked. I have made many search pages before not sure what happened this time :lol:
Thanks for the help.
Scott
Re: xTVDB
Postby Cabinetguy on Sat Apr 10, 2010 9:21 pm
Hey everyone,
I have the Babylon 5 series including the movies. The movies show up on TVDB.com as "specials".
XTVDB doesn't recognize "specials". Is there a way to modify the .ini file to recognize "specials"?
Thank's
Brian
Cabinetguy
Re: xTVDB
Postby Marbles_00 on Wed Jul 14, 2010 4:38 pm
Wondering if someone can help. I'm using this plugin for the first time, and I'm trying to get it to work, but so far, have been unsuccessful.
Basically my seasons are ripped DVD's in the following format:
\\Tower\Disk1\TV Episodes\Lost\Season1\Episode1\Video_TS\Video_ts.ifo and 2 .vob files
Then it would be Episode2\Video_TS\video_ts.ifo and another 2 .vob files
But I can't seem to get the XTVDBConfig.exe file to do anything.
Is there a step by step tutorial on how to use this plugin somewhere?
Thanks in advance.
Re: xTVDB
Postby Marbles_00 on Wed Jul 21, 2010 12:22 am
There is now :D :
viewtopic.php?f=12&t=7332&start=30#p51704
Previous
