xInTheaters v1.5 - 09/28/2008
Re: xInTheaters v1.5 - 09/28/2008
Postby Marbles_00 on Fri Oct 03, 2008 12:53 pm
Yeah, that's why I'm hoping ts can add something (even that hack since it worked) in his code. Maybe have a check box in the setup/config asking whether to show an overlay on a thin client. That way it can be bypassed if not required.
That was a good "hack" and worked well enough, so let's cross our fingers. :D
Postby WannaTheater on Fri Oct 03, 2008 1:24 pm
Note:
If I remember correctly, I believe there is no way in xlobby to have an overlay show on a client (and JUSTthat client) using intheaters. The overlay will always show up on the server as well. This is not good if you are in an actual multi-room multi-user environment. For me I use the Server UI in the living room, and a PPC in the master bedroom. So if I update intheaters from the PPC, using the hack will cause the overlay to show on Server, PPC, and I believe any other clients.
I had planned on writing a small script (scheduled windows task perhaps), which will run the update nightly, but now with this as a dll (and not a script which I could convert to VB) it may be more difficult.
WannaTheater
Postby billberet on Fri Oct 03, 2008 3:24 pm
ok no problem, i can live with that.
the plugin works great otherwise.
Creating a schedule would be great if possible, so by the next day everything is refreshed.
if not, can a plugin be made to run other plugins?
create like a cron job.
for me, i don't mind the overlay showing up on the server while i am on the client because i have the server in the basement server room
so there is no monitor attached.
-bb
Postby WannaTheater on Fri Oct 03, 2008 4:26 pm
I just took care of scheduling of the inTheaters update with the xEvent plugin:
viewtopic.php?t=2446
Using F2 configure, you can assign an event to run at scheduled times.
WannaTheater
Postby billberet on Fri Oct 03, 2008 4:42 pm
sounds good, i have xevent, just haven't installed it yet.
i'll try it out when i get home, i'm sure it will do the trick.
Do you know how to access stills. i notice they download but how do they display?
i want to get every last bit of info out of this plugin.
after that, no more questions. LOL
Postby Marbles_00 on Fri Oct 03, 2008 6:28 pm
billberet wrote:Do you know how to access stills. i notice they download but how do they display?
Stills can be shown by having a text field with "category>Xintheaters>stills" (minus the quotes). Then its just sizing the field to your desired size. The plugin takes care of "slideshowing" through them at a pre-determined rate. I don't think there is a variable to change that rate...only the amount of stills that can be downloaded can be adjusted.
Postby billberet on Mon Oct 06, 2008 5:42 pm
thanks, i tried it and it works like a charm.
now on to the next plugin project, lol
Postby WannaTheater on Sun Apr 26, 2009 1:16 pm
xIntheters seems to be broken for me? Anyone else?
Probably some website changes again.
WannaTheater
Postby Marbles_00 on Sun Apr 26, 2009 2:23 pm
Yep, seems to only find "17", or is it "17 Again", or is it the "movie that has the same concept that's been done sooo many times in the past, and the idea has been just killed"? Either way...that's the only movie being displayed....again, and again....again....again.... :shock:
*EDIT*
Actually, it is only the coverart that isn't changing. The movie title, rating, director, cast, runtime, genre are changing per movie. The other strange thing, is that the title is shown in the skin edit "Text" window, yet it is not being display in the skin...how strange...I thought I had a text sizing issue, but it is just not showing.
Postby WannaTheater on Sun Apr 26, 2009 2:47 pm
HA! Mine gets stuck on "12 Rounds." Same deal... Everything seems to update except for COVERART and PREVIEW. No previews are showing up.
WannaTheater
Postby WannaTheater on Mon Apr 27, 2009 9:31 am
Looks like the variable "MovieInfo_m title" is not correctly being populated... regex in code probably needs to be changed. Anyone have intheaters plugin source?
WannaTheater
Postby WannaTheater on Mon May 04, 2009 12:36 am
Still not working.... Anyone heard from tswhite? I'm bummed because this was a big "that's cool" from everyone that saw my system :)
WannaTheater
Postby Marbles_00 on Fri May 08, 2009 3:51 pm
Still wondering where he is. Hope he's okay. I just implemented the Post Processing routine and it worked great....just wish the rest of the plugin worked just as well. :(
TS...we need you buddy.
Postby WannaTheater on Fri May 08, 2009 4:15 pm
Hope he's OK as well!
I have his original xScript version which I may be able to modify... if I ever get some free time.
If TSW does show back up, I recommend he pull out each of the webpage regex statements into something like an XML input file, so if the webpage format changes (but still contains the same information), we can just edit the REGEXes to correctly find the right info. This was done with the TVMan application source that was provided to me awhile ago.
WannaTheater
Postby Marbles_00 on Sun Jul 26, 2009 7:45 pm
ANYONE around to get this plugin working properly again?
