Open up xMusic.ini and check that the correct class name is specified (for milkdrop 2 its MilkDrop2
[Settings]
xxxx
xxxx
Milkdrop Class Name = MilkDrop2
S Pittaway wrote:Check that you have told the plugin to use Milkdrop 2
Open up xMusic.ini and check that the correct class name is specified (for milkdrop 2 its MilkDrop2)
[Settings]
xxxx
xxxx
S Pittaway wrote:your copy if winamp works fine for me. milkdrop 2 fires up and is locked to the correct bit of the screen on my skin.
the plugin looks for a control with an id of "xmusic.milkdrop.XXXX" where XXXX is the name of the screen, if it finds it it will size the milkdrop window to fit that control.
i guess you dont have a control with the right id present?
S Pittaway wrote:it works for me
i have your copy of winzip so all thats left is zips of your skin the xmusic plugin folder
slaman wrote:Hi Pittaway,
Thanks for the responses. I actually don't use an overlay for the visualization screen, I use the goto command.
In any event, I tried using what you suggested, with the wait, but it still didn't work. Then I tried to put %screenname% in one of the text boxes, and it stayed as %screenname%! I think the issue may be that this xlobby variable that you're expecting isn't defined in my instance. Is this possible? If so, how do I get it back?
11:07:04 AM:083 STARTUP Plugin initialised
11:07:04 AM:093 TimerStateDelay =250
11:07:04 AM:093 TimerTrackDelay =500
11:07:04 AM:093 AutoHideControls = True
11:07:04 AM:093 AutoPositionMilkdrop = False
11:07:04 AM:093 PlayPauseButtonPlay = 4
11:07:04 AM:093 PlayPauseButtonPause = ;
11:07:04 AM:094 CheckWinampPlayState = True
11:07:04 AM:094 AutoUpdatePlayedTimes = True
11:07:04 AM:094 AutoUpdatePlayedTimes = 500
11:07:04 AM:350 UpdatePlayState Play state change to paused
11:07:04 AM:355 INI EVENT GROUP > Runing Section 'On Play State Change'
11:07:04 AM:367 INI EVENT GROUP < Finished
11:07:12 AM:243 Track Change Track changed from '' To 'E:\Hip Hop\50_Cent_-_In_Da_Club-Remix_Promo_CDS-2003-SOL\01-50_cent_-_in_da_club_(datrooth_remix)-sol.mp3'
11:07:12 AM:245 FindPlayingSong Track # 1, Track=E:\Hip Hop\50_Cent_-_In_Da_Club-Remix_Promo_CDS-2003-SOL\01-50_cent_-_in_da_club_(datrooth_remix)-sol.mp3
11:07:12 AM:245 Loading album
11:07:12 AM:245 Small album, doing a full search on param
11:07:12 AM:249 Track found
11:07:12 AM:249 Auto updaing last played time
11:07:12 AM:259 INI EVENT GROUP > Runing Section 'On Track Change'
11:07:12 AM:260 INI EVENT GROUP < Finished
11:07:12 AM:413 UpdatePlayState Play state change to playing
11:07:12 AM:418 INI EVENT GROUP > Runing Section 'On Play State Change'
11:07:12 AM:418 INI EVENT GROUP < Finished
11:07:16 AM:182 EXECUTE > Command = milkdrop.start
11:07:16 AM:183 Params[0] =
11:07:18 AM:677 EXECUTE < Command completed
11:07:23 AM:118 EXECUTE > Command = milkdrop.stop
11:07:23 AM:119 Params[0] =
11:07:23 AM:620 EXECUTE < Command completed
11:07:46 AM:131 EXECUTE > Command = milkdrop.start
11:07:46 AM:131 Params[0] =
11:07:46 AM:186 EXECUTE < Command completed
11:07:47 AM:417 EXECUTE > Command = milkdrop.stop
11:07:47 AM:417 Params[0] =
11:07:47 AM:919 EXECUTE < Command completed
11:07:48 AM:968 EXECUTE > Command = milkdrop.start
11:07:48 AM:968 Params[0] =
11:07:51 AM:373 EXECUTE < Command completed
11:07:57 AM:329 EXECUTE > Command = milkdrop.stop
11:07:57 AM:330 Params[0] =
11:07:57 AM:831 EXECUTE < Command completed
11:08:33 AM:541 EXECUTE > Command = milkdrop.start
11:08:33 AM:541 Params[0] =
11:08:33 AM:753 EXECUTE < Command completed
11:08:53 AM:215 EXECUTE > Command = milkdrop.stop
11:08:53 AM:216 Params[0] =
11:08:53 AM:717 EXECUTE < Command completed
11:10:12 AM:725 EXECUTE > Command = milkdrop.start
11:10:12 AM:725 Params[0] =
11:10:12 AM:977 EXECUTE < Command completed
11:11:09 AM:111 EXIT Plugin closed
