MediaPortal TvEngine3 plugin WWW
Re: MediaPortal TvEngine3 plugin WWW
Postby lar282 on Mon Feb 09, 2009 7:52 am
mememe wrote:Thanks for the reply. I've been busy this weekend, I'll give it another go in the next couple of days and get back to you.
here's my skin if u want to test the mp stuff.
http://www.xlobby.com/files/Shaggy/slavedream.rar
Postby Cabinetguy on Thu Feb 12, 2009 3:16 am
Hi Lasse,
Do you have fm radio working through mediaportal? I haven't been able to get any stations.
I'm currently using winamp v tuner plugin but would like to use mediaportal so that I have fewer programs to setup.
Brian
Cabinetguy
Postby rembetis on Tue Sep 08, 2009 12:23 pm
Hi Lasse,
Sorry to be a pain, but would it be possible to get the files/plugin that worked with version 0.2.1? That's the only version that works with a Hava Monsoon TV tuner. Also, is it possible to do the complete (0.2.1) install of MediaPortal and then still use your plugin, or must I use the modified TVEngine?
Thanks.
rembetis
Postby lar282 on Tue Sep 08, 2009 12:56 pm
rembetis wrote:Hi Lasse,
Thanks.
Sorry I don't have that old files left.
I just built the 1.1.0 release.
Is that a analog tuner?
U must use a modified install. I change 5-6 files within MP
Postby rembetis on Tue Sep 08, 2009 1:01 pm
Any out there have these files saved somewhere? They are linked on the external (free) xlobby sites, but that just links back to this thread. I still have the 1.06 and 1.08 versions saved, but nothing 2.0. Thanks in advance.
http://www.xlobby.com/files/Shaggy/Tv_f ... .0.0.0.rar
http://www.xlobby.com/files/Shaggy/Tv_f ... _Skins.rar
p.s. to answer your question, Lasse, the Hava is not really a tuner at all per se, it just connects to a cable box like the SlingBox. I am currently able to tune & change all the channels with the 0.2.1 version of MediaPortal, but not the new one.
rembetis
Postby lar282 on Tue Sep 08, 2009 1:09 pm
I'll check my archive when I get home.
Have u read this?
http://forum.team-mediaportal.com/telev ... old-42285/
Postby rembetis on Tue Sep 08, 2009 1:16 pm
lar282 wrote:I'll check my archive when I get home.
Have u read this?
Thank you kindly. Yeah, as best I can tell, that post is quoting this thread, the final post on which indicates that this works only on the "discontinued" or previous versions of Mediportal, not the new tvserver/client version.
rembetis
Postby rembetis on Tue Sep 08, 2009 1:20 pm
Holy crap, I think I found it. I have a file called: MediaPortal2.0.0.0RC9.rar in an old Xlobby folder, together with MP_Skins.rar and Xlobby2.0.0.0RC9.rar. Hopefully these will work.
rembetis
Postby gnaffs on Tue Oct 27, 2009 12:21 pm
Hej Lars,
Any change that you can update the first post with the 1.1 version?
Best Regards
Krister
gnaffs
Postby lar282 on Tue Oct 27, 2009 1:25 pm
gnaffs wrote:Hej Lars,
Best Regards
Krister
I'll upload it tonite or tomorrow. Be aware that they changed ALOT in the structure so your settings will dissapear.
Postby Cabinetguy on Sat Apr 10, 2010 9:02 pm
Hi lasse,
How do you like the newest 1.1 release? Is it worth changing from your last 1.02 version?
If so, would you be willing to post your latest?
As always thank you
Brian
Cabinetguy
Postby lar282 on Sun Apr 11, 2010 6:34 am
Cabinetguy wrote:Hi lasse,
As always thank you
Brian
I'm running the svn from last week now and it's stable. One of my friends is also running the pre RC2, and he's happy aswell.
I can upload it tomorrow if u want.
Postby Cabinetguy on Sun Apr 11, 2010 4:06 pm
That would be great.
Has anything changed so that I won't be able to use my current skin?
Thank you again for sharing your work.
Brian
Cabinetguy
Postby lar282 on Sun Apr 11, 2010 6:19 pm
Cabinetguy wrote:That would be great.
Brian
They changed so much that a upgrade is not possible. Only possible from rc1 ->Rc2 and then RTM
Think they change skin aswell. Maybe u should install there rc1 full version then change your skin then upgrade using mine
Postby Cabinetguy on Sun Apr 11, 2010 7:31 pm
I thought this might be the case.
Oh well, I have been wanting to make changes to my skin anyway. I've been wanting to include elements of the Black glass skin into my xlobby skin as well as MPTV skin. I guess I will start with that.
Brian
Cabinetguy
