MediaPortal TvEngine3 plugin WWW
Re: MediaPortal TvEngine3 plugin WWW
Postby lar282 on Tue May 20, 2008 12:49 pm
it wont work if XL is started, and the F2 in XL wont work either. U need to edit the XmpTv.xml and change the
<section name="TvEngine3">
<entry name="hostname">192.168.0.9</entry>
AND port 6666 needs to be open. Are u having the server and XL client on the same machine?
post the Xlobby\log\XmPTv.log here please
Postby Cabinetguy on Sun May 25, 2008 11:33 pm
Hi Lasse,
I have it all working now! Even have the software changing channels on the stb.
I used the schedules direct plug-in, and the new ir suite with tve3 blaster.
I just have 2 more questions.
1. As far as the tvguide.xml file, the schedules direct plug-in doesn't let you change where it places the file. so is there an easy way to keep both directories synchronized?
2. I need to come up with a skin to match Baddabings HTCC_CF skin. I tried using a copy of your skin with renamed images from my skin, cleared the cache in media portal, but nothing changed
Thanks again for this great plug-in !
Brian
Cabinetguy
Postby lar282 on Mon May 26, 2008 6:13 am
1:/have a bat file to copy both files
2: TRY to delete the packedgfx*.png in the skin dir. I do not knwo to much about skinning in mp. I do know that XL is soooo much better and easier to skin. I don't think I can help u out if it doesn't work unless u send me the replaced images, then I can try some here.
Postby Cabinetguy on Mon May 26, 2008 4:31 pm
Hi Lasse,
Wow! You weren't kidding about skinning Media Portal,what a PITA !
But I now have a skin that very closely matches Baddabing's HTCC_CF skin.
My wife and kids like it.
How do I find info on how to make a batch file? I have never worked with them before, but I would like to learn.
Thank you,
Brian
Cabinetguy
Postby lar282 on Tue May 27, 2008 8:36 am
just create a schedule task that runs everyday and point to a bat file
REM---start bat file
copy /Y "c:\Fullpatch_to_you_xml_file\TvGuide.xml" "c:\destPath\xlobby\xmltv\TvGuide.xml"
REM ----END bat file
Postby Cabinetguy on Mon Jul 21, 2008 10:26 pm
Hi Lasse,
My family and I have been using your plugin for a while now and love it.
I do have one last question. Is it possible to get the mouse pointer to show in mediaportal?
It sure would make navigation easier.
I looked for a while but didn't find a setting for this.
Thank you,
Brian
Cabinetguy
Postby lar282 on Tue Jul 22, 2008 7:35 am
Cabinetguy wrote:Hi Lasse,
Thank you,
Brian
Thats a setting in mediaportal if I remember correctly. Open configuration.exe and look under the first few tabs. should be an entry about the mouse.
RC2 is out and I will upload it when I get back from my vacation.
Works like a charm so far.
Postby Cabinetguy on Tue Jul 22, 2008 9:52 pm
Thank you.
I'm looking forward to RC 2.
Oh, enjoy your vacation!
Thank's
Brian
Cabinetguy
Postby Cabinetguy on Fri Aug 08, 2008 7:44 pm
Hey Lasse,
Any word on RC-2 yet?
Brian
Cabinetguy
Postby lar282 on Sat Aug 09, 2008 9:07 am
I'm running pre RC3 now and if I do not find any wierd thing then I will post it here in a few days
Postby Cabinetguy on Wed Aug 20, 2008 12:30 am
Hey Lasse,
How's that RC 3 working?
Brian
Cabinetguy
Postby lar282 on Wed Aug 20, 2008 7:19 am
just fine. Trying to upload it to the xlobby server but it fails all the time...Gonna try some more during the day
Postby lar282 on Wed Aug 20, 2008 4:31 pm
I think I managed to upload the Update_Pack.zip
http://www.xlobby.com/files/Shaggy/MpTv ... e_Pack.zip
Hopefully its not corrupt. Somehing is fishy when I upload to the xlobby servern.
WARNING: This update will erase your tvserver settings. export and write down all your settings in tvserver cause they will be lost:
unpack and edit the update_all.bat file and see that the paths are correct for YOU.
execute the update_all.bat
NOTE: This update pack will only work if u installed from the first post in this thread.:NOTE
NOTE2: Some user i the MP forum has reported that the tvservice does not like hibernate/resume well. Seems like this little application solves this issue.
http://forum.team-mediaportal.com/attac ... .0.0.3.zip
Postby Cabinetguy on Fri Aug 22, 2008 12:30 am
Hi Lar,
Thank you for uploading the new update.
I think that the upload is corrupted somehow.
Here is my install log
install_0.9.2.19931_2008-08-21_18-51-06.log
(1.25 KiB) Downloaded 524 times
If you look at the setup.exe section there are errors. When I try to enter the TV Server config program a UNC.libs error pops up and says setup.exe must be located inside team mediaportal directory.
Edit: Please disregard this post. Problem fixed.
Thank you,
Brian
Cabinetguy
Postby Cabinetguy on Sun Aug 24, 2008 6:57 pm
Hi Lasse,
Just wanted to say thanks for posting the update.
It works better than the last version, I have a mouse pointer now! That makes my wife very happy.
Thank's
Brian
Cabinetguy
