XMail plugin www
Re: XMail plugin www
Postby dalanik on Tue Jun 10, 2008 1:18 pm
S Pittaway wrote:i am guessing you are writing your own xml file? because something is forgeting to replace the special xml chars (&, >, < etc)
Yes, It was easier at the time :-) I'll have a look...
Postby dalanik on Tue Jun 10, 2008 8:56 pm
Can you try this, if it fixes invalid XML characters?
http://xlobby.lanik.org/XMail.dll
D.
Postby S Pittaway on Wed Jun 11, 2008 8:19 am
cheers, i will give it a try later.
Postby S Pittaway on Wed Jun 11, 2008 3:19 pm
I gave it a quick try, but I now get a crash when i call XMail>GetMail.
System.NullReferenceException: Object reference not set to an instance of an object.
   at XMail.XMail.Clean(String TexStr)
   at XMail.XMail.GetMail()
   at XMail.XMail.Execute(String fullcommand)
   at xlobby2.Command.Run(Control control)
   at xlobby2.Setup.button56_Click(Object sender, EventArgs e)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
    Assembly Version: 2.0.8150.5
    Win32 Version: 2.0.08150.05
    CodeBase: file:///C:/Program%20Files/xlobby/xlobby2.exe
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.ActiveHomeScriptLib
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/xlobby/Interop.ActiveHomeScriptLib.DLL
XPluginSDK
    Assembly Version: 1.0.2817.26334
    Win32 Version: 1.0.2817.26334
    CodeBase: file:///C:/Program%20Files/xlobby/XPluginSDK.DLL
System.Management
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Interop.X10
    CodeBase: file:///C:/Program%20Files/xlobby/Interop.X10.DLL
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
DShowPlayer
    Assembly Version: 0.0.0.0
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/xlobby/DShowPlayer.DLL
msvcm80
    Assembly Version: 8.0.50727.1433
    Win32 Version: 8.00.50727.1433
    CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2/msvcm80.dll
xlobbydvdcopy
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xlobbydvdcopy.dll
xusbuirt
    Assembly Version: 1.0.2988.30813
    Win32 Version: 1.0.2988.30813
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xusbuirt.dll
xDatabase
    Assembly Version: 1.0.3077.28542
    Win32 Version: 1.0.3077.28542
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xDataBase/xDatabase.dll
xDigiTv
    Assembly Version: 1.0.2902.16818
    Win32 Version: 1.0.2902.16818
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xDigiTv/xDigiTv.dll
Mail
    Assembly Version: 2.5.2352.26470
    Win32 Version: 2.5.2352.26470
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/XMail/Mail.dll
XMail
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/XMail/XMail.dll
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
xMono
    Assembly Version: 1.0.3028.28150
    Win32 Version: 1.0.3028.28150
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xMono/xMono.dll
xMusic
    Assembly Version: 1.0.3042.26920
    Win32 Version: 1.0.3042.26920
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xMusic/xMusic.dll
XRemote
    Assembly Version: 0.2.1966.29535
    Win32 Version: 0.2.1966.29535
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/XRemote/XRemote.dll
texluygc
bc_xbjhm
xSleep
    Assembly Version: 1.0.2942.31190
    Win32 Version: 1.0.2942.31190
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xSleep/xSleep.dll
xTopPicks
    Assembly Version: 1.6.0.0
    Win32 Version: 1.6.0.0
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xTopPicks/xTopPicks.dll
XWeather
    Assembly Version: 1.0.3023.23285
    Win32 Version: 1.0.3023.23285
    CodeBase: file:///C:/Program%20Files/xlobby/plugins/xweather/XWeather.dll
Interop.Shell32
    CodeBase: file:///C:/Program%20Files/xlobby/Interop.Shell32.DLL
Mail
    CodeBase: file:///C:/Program%20Files/xlobby/Mail.DLL
enabled.
For example:
<configuration>
</configuration>
I end up with a empty xmail.xml file so i guess its poping on the file write.
Cheers, Sean.
Postby S Pittaway on Wed Jun 11, 2008 3:24 pm
if you are using that function i posted try
static public string XmlEncodeString(string XMLString)
  if (XMLString == null || XMLString == "" )
    //its already safe
  else
      XMLString = XMLString.Replace("\001", ".");
      XMLString = XMLString.Replace("\002", ".");
      XMLString = XMLString.Replace("\003", ".");
      XMLString = XMLString.Replace("\004", ".");
      XMLString = XMLString.Replace("\005", ".");
      XMLString = XMLString.Replace("\006", ".");
      XMLString = XMLString.Replace("\007", ".");
      XMLString = XMLString.Replace("\008", ".");
      XMLString = XMLString.Replace("\009", ".");
      XMLString = XMLString.Replace("&", "&amp;");
      XMLString = XMLString.Replace("<", "&lt;");
      XMLString = XMLString.Replace(">", "&gt;");
  return XMLString;
}//XmlEncodeString
I never let nulls into my plugin, so i don't bother checking for them :)
Postby dalanik on Thu Jun 12, 2008 7:01 am
Could be anything, I just edited it and compled w/o checking :-)
I already have similar function to which I added codes in your source. I'll have a look....
D.
Postby smarty on Sun Dec 14, 2008 6:19 pm
Folks,
Is this plugin now working?
I just tried V.10b, and it appear to check my e-mail (confiremed by the log file), but when I re-start, the mail.xml database causes the system to crash. I am no sofware guy, so this could be the same issues as mentioned previously.
smarty
Postby smarty on Mon Jun 15, 2009 12:44 pm
Bump.... Dalanik are you still out there????
smarty
Postby dalanik on Tue Jul 07, 2009 9:10 am
Hello,
I'm still here but have been busy with other things ;-) I will try to force myself to have a look at this one during summer.
D.
Previous
