xAP HomeSeer plugin update released.
Postby CouchPotatoe on Mon Sep 26, 2005 11:18 am
For those of you using the xAP XLobby plugin with HomeSeer v2 -James has released an update to the HomeSeer xAP plugin component. Addressed are several bug fixes, a cleaner hub registration on startup/shutdown and a full transition to the web based interface.
http://www.mi4.biz
Kevin
CouchPotatoe
Postby Aaron on Wed Sep 28, 2005 2:53 am
are there going to be updates to the Homeseer 1 version?
A lot of people are not upgrading to v2... I'm not.
my setup info... http://livinone.googlepages.com
XBMC, Homeseer Home Automation, Multi-Zone Audio, Paradigm-Parasound-Onkyo-Velodyne Home Theater, Mitsubishi 65" HDTV ... soon XLobby!
Aaron
Postby ingalls on Wed Sep 28, 2005 1:00 pm
I test homeseer v2, I didn't find really new things
All the settings are available via internet explorer
There is something I don't like, homeseer always stays near the start button... impossible to let it in the system tray...
Member of XLobby FR Team
Releases from the French team
ingalls
Postby CouchPotatoe on Wed Sep 28, 2005 1:18 pm
I can't really speak for James but I believe the updates are focussed on V2 of HomeSeer - I don't think (m)any new features will appear in the V1 plugin. Some of the architecture is now quite different.
Ingals.. re HS2 - can you not run it as a service ? I know at the moment the 'new features' side of HS2 isn't so appealing over V1 but it was a major re- write for them and I expect once they have that adopted and stable then new things will start to appear.
Kevin
CouchPotatoe
Postby ingalls on Thu Sep 29, 2005 6:12 am
CouchPotatoe wrote: Ingals.. re HS2 - can you not run it as a service ? I know at the moment the 'new features' side of HS2 isn't so appealing over V1 but it was a major re- write for them and I expect once they have that adopted and stable then new things will start to appear.
Kevin
they said it is possible but I didn't search to do it already. I will take a look to the online help.
ingalls
