xap plugin not appearing
Postby HomersBrain on Wed Sep 21, 2005 7:59 pm
I've just installed xlobby and want to use it with Homeseer, but I'm not getting anywhere with the xap plugin.
I've downloaded it from here: http://www.france.xlobby.com/plugins/xA ... Xlobby.zip
and unzipped it into the xlobby plugins folder but it's not appearing when I go to the plugins tab within Xlobby (F2).
Is there anything else I should be doing it activate it?
Thanks in advance.
Mike
HomersBrain
Postby lar282 on Thu Sep 22, 2005 6:10 am
Found this in the Xap thread
4) Installation
First, you have to install all your xAP applications.
Be sure you have installed the latest Xlobby version http://www.xlobby.com/xlobby2.zip then download the plug and decompress it in your Xlobby directory http://www.france.xlobby.com/forum/ptri ... plugin.zip.
It will create
- 6 files in your Xlobby directory (6 DLL)
- 1 folder in plugins directory named xAP-Xlobby with 2 files: AP-Xlobby.dll and xAP.ini
- 1 folder in xAP-Xlobby directory named Schema with 2 files: ACTIONS.XML and EVENTS.XML.
http://www.xlobby.com/forum/viewtopic.p ... 6&start=75
PS:Post in the support section:DS
Postby HomersBrain on Thu Sep 22, 2005 6:33 am
Thanks Lasse - I must have been using the wrong version of the plugin. It's appearing now, and talking to the xap hub.
(I'll post in the correct forum next time!)
Mike
HomersBrain
