DVD Profiler import utility - need databases for testing
Postby jovial_mood on Sat Aug 20, 2005 7:50 am
I'm writing a utility for importing DVD Profiler information into Xlobby. Though I'm not a programmer and it's not a plugin I'm planning on making the utility publicly available for download for others like me interested in importing more data than Xlobby does as default. I need to test it using other databases than my own though.
I'm interested in both DVD Profiler collection.xml and Xlobby movies.xml.
My adress is 'engstrom(at)bahnhof(dot)se'
Here are some screenshots of the actual utility.
http://user.bahnhof.se/~engstrom/dxc_screenshots.htm
Nothing fancy, but I believe it does it's trick. At least from my point of view. :)
jovial_mood
Postby lar282 on Sat Aug 20, 2005 11:55 am
check mail
Postby mzemina on Sat Aug 20, 2005 12:32 pm
lar282 wrote:check mail
OT: How did you send him mail since PM is turned off and he has no email?
mzemina
Re: DVD Profiler import utility - need databases for testing
Postby Colby on Sat Aug 20, 2005 12:53 pm
jovial_mood wrote:My adress is 'engstrom(at)bahnhof(dot)se'
Does that help?
"Get creative or go home!"
Postby mzemina on Sat Aug 20, 2005 4:26 pm
Thanks!
But it looks like he doesn't allow email from unknown people!
213.136.33.1 does not like recipient.
Remote host said: 550 <ngstrom<at>bahnhof<dot>se>: Recipient address rejected:
User unknown in local recipient table
mzemina
Postby jovial_mood on Sat Aug 20, 2005 4:40 pm
lar282,
Thanks for the files.
mzemina,
The reason for typing the address in such stupid way is that I don't like web bots collecting it for spam purposes.
jovial_mood
Postby jovial_mood on Sat Aug 20, 2005 4:56 pm
mzemina wrote:But it looks like he doesn't allow email from unknown people!
The e-mail address is 'engstrom(at)bahnhof(dot)se'
Replace (at) with @ and (dot) with .
jovial_mood
Postby mzemina on Sat Aug 20, 2005 8:24 pm
Thanks - but for some reason the mailer deamon was not able to deliver the message. The reason was previously posted. I just changed the '@' and '.' to <at> and <dot> to keep electronic email sniffers at bay.
Mikeb
mzemina
Postby jovial_mood on Sun Aug 21, 2005 7:59 am
mzemina,
That's very odd, I haven't had any previous problems with recieving email from unknown addresses. I notice though that there's a missing 'e' in the beginning of the address in your error message. It should read <engstrom<at>bahnhof<dot>se>, not <ngstrom<at>bahnhof<dot>se>.
Anyway, you can also use the address 'akr681x(at)tninet(dot)se'. It's another ISP so if Bahnhof for some reason has blocket IP's in your range it's not very likely Tninet has. I'm sorry for the inconvenience.
jovial_mood
Postby mzemina on Sun Aug 21, 2005 8:29 pm
Dropping the first 'e' in your email address must have been the problem! I sent it again.
mzemina
Postby Russell on Tue Dec 20, 2005 9:20 pm
Can you post a link to the file. I want to be able in import Aspect Ratio.
Russell
Postby lar282 on Wed Dec 21, 2005 7:54 am
Russell wrote:Can you post a link to the file. I want to be able in import Aspect Ratio.
http://www.xlobby.com/forum/viewtopic.p ... ght=#24123
Postby Mac on Wed Jan 18, 2006 12:19 pm
I get an error message when I execute dxc.exe. Did I miss something?
Mac
Postby jovial_mood on Wed Jan 18, 2006 3:06 pm
What does the error message say?
jovial_mood
Postby Russell on Wed Jan 18, 2006 10:14 pm
You need .net version 2 for this to work.
Russell
