accessing USB HID with C#
Postby Mullaly on Thu Jul 07, 2005 11:33 am
Hi,
I'm trying to create a plugin for an AVermedia USB FM radio. I have attempted to create a C# dll using the steps on this website and I get it comming up in Xlobby. I however cannot access and write the data required to the HID device using windows API calls to the HID class.
I have looked on the "HID page" and other USB resources for sample code but I can't get data written to the device.
Does anyone have an example of how to do this in c#?
Alternitively does anyone know how I can use delph to give me the dll exports required to make a plugin for Xlobby? I have radio working fine in a stand alone delphi application.
I guess I can just have a button that launches the windows application however it would be nice to be able to control the radio from Xlobby.
Thanks...
Mullaly
Postby badubo on Thu Jul 07, 2005 12:12 pm
if the functions you need are located in a standard dll, you can use the interop DllImport procedure for importing the method:
[DllImport("mydll.dll")]
public static extern int myFnct();
See the msdn documentation for more information
create a dll with winapi exports and use DllImport from your plugin
Badubo
Member of XLobby FR Team
badubo
Postby Mullaly on Fri Jul 08, 2005 2:13 am
Thanks badubo,
Looks like the problem was a dll function not working correctly, I have no idea why.
A seperate application might be the quickest way to get things going for now might revisit it later on. If I get a plugin going I'll post it up for everyone.
Thanks for your help.
Mullaly
