Where do I get the cdex plugin
Postby synchro on Sun Feb 06, 2005 2:40 am
Help... I can not find the cdex plugin it is not in my plugin directory... nor can I find a place to download it?
synchro
Postby jowaldo on Sun Feb 06, 2005 3:26 am
You should be able to just go to the setup menu (f2) then go to the download tab and download it from there. It will put it in the downloads folder where you are running xlobby.. Then just put it in your plugins folder, and restart xlobby.
If that doesn't work for you, you can get it here too:
http://www.xlobby.com/files/jowaldo/CDEX.zip
Thank You...
Postby synchro on Mon Feb 07, 2005 7:26 pm
Thank you jowaldo...
The download tab is not working for this file... I thought I was doing some thing wrong...
I am working with you skin right now... Thanks for all the great work...
synchro
Users browsing this forum: Google [Bot] and 11 guests
